Proving solutions of an ODE of the form y''+by'+cy=0
  • Thread starter Thread starter nemma14778
    Form Ode
The discussion centers on proving that the set of solutions for the ordinary differential equation (ODE) of the form y'' + by' + cy = 0 constitutes a vector space. The participant demonstrates Axiom #1 by showing that if u and v are solutions, then any linear combination c1u + c2v is also a solution, confirming closure under addition. The conversation also touches on the necessity of verifying additional axioms (4, 5, and 9) to fully establish the vector space properties. A suggestion is made to utilize the method of variation of parameters to confirm the existence and uniqueness of solutions.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with vector space axioms
  • Knowledge of linear combinations and their properties
  • Basic concepts of solution spaces in differential equations
  • Study the complete set of vector space axioms and their implications
  • Learn about the method of variation of parameters for solving ODEs
  • Explore the concept of linear independence in the context of solution spaces
  • Investigate the existence and uniqueness theorems for ODEs
Students and educators in mathematics, particularly those focusing on differential equations and linear algebra, as well as researchers interested in the theoretical foundations of vector spaces in the context of ODEs.
nemma14778
The set of solutions of an ODE of the form y''+by'+cy=0 forms a vector space. To convince yourself of that, prove that axioms 1,4,5 and 9 of the definition of a vector space hold for this set of solutions. (You may want to check the others as well, but no need to present their proof.)
I started to prove the first axiom as follows:
Axiom #1: If u and v are objects in V, then u + v is in V.
If we let c1u and c2v be two solutions to our second order differential equation, then c1u + c2v must be a solution for the second order differential equation for any constants c1 and c2.
F(y) = 0 = (c1u+c2v)’’ + b(c1u+c2v)’ + c(c1u+c2v)
0 = c1u’’+c2v’’ + bc1u’+ bc2v’ + cc1u+cc2v
0 = c1u’’ + bc1u’ + cc1u + c2v’’ + bc2v’ + cc2v
0 = c1(u’’ + bu’ + cu) + c2(v’’ + bv’ + cv)
0 = c1F(u) + c2F(v)
0 = c1(0) + c2(0) = 0 + 0 = 0
0 = c1F(u) + c2F(v)
I don't see any question here. Also I don't know what axioms 1,4,5,9 are in your text. However, in your argument above you want to start with u and v, not c1u and c2v. I think you will find that your argument will show that u and v are solutions then so is c1u + c2v, which may solve more than one of your required properties.
I do not understand any of that stuff. Any way if one wanted to verify existence uniqueness without apeal to general theorems a standard method is to apply variation of parameters to deduce that y is a solution if and only if it is a linear combination of a basis of the solution space. This also makes it easy to show te solution space is a vector space.
10K
  • · Replies 0 ·
