Reinventing the wheel - how often does it happen in research?
  • Thread starter Thread starter Simfish
    Research Wheel
The discussion revolves around the concept of "reinventing the wheel" in research, particularly in the context of coding and data projection tasks. Participants explore the frequency and implications of duplicating efforts in research, especially when resources are limited or when existing solutions are not readily available. The conversation touches on the nature of grunt work in research and how it relates to the perception of one's contributions.
  • Meta-discussion
  • Some participants express that grunt work is common in research, with one noting that reinventing the wheel is an overused cliché.
  • Others argue that while grunt work is necessary, there is a desire to minimize it if possible, suggesting that finding existing solutions could save time.
  • A participant questions the validity of their research contributions when the tasks seem repetitive or basic, raising concerns about how to present their work to others.
  • There are discussions about the time investment required for coding versus finding existing code, with varying opinions on what constitutes the best use of time.
  • Some participants share experiences of other undergraduates working on similar projection tasks, indicating that such projects are common and often do not require deep knowledge.
  • Concerns are raised about how to present research contributions accurately, with suggestions that it is important to acknowledge personal contributions even if they are minor.
  • One participant mentions that their peers did not publish their summer research, leading to questions about how they presented their work and whether they used their mentor's ideas.
Participants generally agree that grunt work is a significant part of research, but there is no consensus on whether reinventing the wheel is common or how to best present one's contributions. The discussion remains unresolved regarding the balance between personal contributions and the broader project context.
Participants express varying opinions on the efficiency of coding from scratch versus using existing resources, highlighting the dependence on specific project scopes and individual preferences. There are also unresolved questions about the expectations for presenting research contributions in academic settings.
This discussion may be useful for undergraduate students involved in research, particularly those grappling with the nature of their contributions and how to communicate them effectively. It may also interest researchers considering the balance between original work and utilizing existing solutions.
Simfish
So basically, for LSST research, a LSST project scientist told me to work on Python code that could project the sky onto a 2D grid, which is what I did. It was awfully hard to find code (especially Python-based code) that could project the sky on a 2D grid - so the task he gave me was necessary given the limited resources that were available. Is reinventing the wheel common in research?
Ah yes, it's the Simfish inane question of the week.
Reinventing the wheel is an overused cliché. Is it common to do a lot of grunt work when doing research? Yes. Reinventing the wheel? Not really. Projecting a 3D structure onto a 2D surface is something that happens in millions of applications every day.
Yes, I have no problem with doing grunt work at all. But if I can do the same thing with less work, then yes, I would like to reduce it (so that more of my time is spent on something that helps). If I can't reduce it, I continue on with the task.
If that's the case, then isn't it more likely that online code would be available for it? (of course, one cannot always expect it)
Also, there are times when prof may even put my name as a coauthor for reinventing the wheel (of course I'm grateful to him for that). But then can I tell other people that I'm doing research when what I'm doing isn't really research?
If that's true, why do you constantly complain about it? Seriously. I think you should take advantage of your research experience and ask yourself 'if this generates so many complaints now, is this something I want to do as a career?'
To answer your question, if it takes me time t to code something up and time 2t to find something that almost does what I want, 3t to understand how it does it, and another 2t to adapt it to my exact needs, what is the best use of my time?
Yes it is. Most research is this sort of grunt work.
I really think it depends on the scope of what you're doing. The principle doesn't necessarily work, sticking with code example, if you'll be making Natural language Processing the time used to duplicate previous efforts would not be well spent. If you want to make a C++ 3D numerical Schrödinger eqn solver, maybe it is faster to do it yourself, from scratch.
Those are good points. I'm still willing to do it if necessary. That still doesn't prevent me from having a preference ranking though.
What I mostly wanted was some context of what I did relative to other undergrads, because when I'm describing my work to other people, I want to anticipate how they will respond to it.
Look up the projection transformation matrix.
I know of at least one undergraduate (who was at the REU I attended last summer) whose major summer project was a projection algorithm for Mars images... Another dealt with reconstructing the surface of asteroids/comets based on a few images of their surface (more projecting). The whole process is probably rather common for undergraduates to do since it doesn't require deep knowledge of what's going on but is useful and necessary since it needs to happen with a lot of data.
Oh nice - thanks for the answer! Which finally clarifies the point that I originally wanted to make but didn't find the words for in the OP. Namely, if your role in the project is projecting, then how would you present the role of your project in a presentation for a symposium? Like an undergraduate research symposium? Would you simply present your mentor's ideas in the symposium, and pretend that those ideas were your own? It seems that *every* undergrad in the undergrad research symposium at my school seems to pretend that their research is their own - they don't say that their role was to only plot the thing.
As for those undergrads you mentioned, how did they even write their papers? Did they have to use their mentor's ideas for their papers, rather than their own ideas?
I don't think either of them published their research for the summer.
It seems to me, though, that when you're giving a presentation or some other such to a general audience (that is, an audience beyond the research group you're working with!), it makes sense to outline the project in the general sense a professor would do. But you should probably at least include a section on what you personally did and how it benefited the project as a whole.
Overall it seems to me like a matter of taste in how you want to do it. I took the route described above when I gave a talk about my summer research, but I could have spent the whole time describing what I personally did, or gloss over this and discuss the main points of the research as a whole. But like you said, it seems to me a bit disingenuous to not explain what your personal contribution was to the project, even if it was minor.
Oh, don't you have to give a presentation on your REU project though? Or write a small paper to show what you've learned? Obviously, it wouldn't have to be a peer-reviewed paper.
Oh okay I see. By what you personally did, did you mean "it makes sense to outline the project in the general sense a professor would do"? Did you discuss your personal contribution?
We had to give a talk, and that's what I was referring to in the main part of my response.
Yeah. Since I couldn't expect more than a few people in the audience to be familiar with numerical relativity, I took the time to explain some of the fundamental things about it. Things like a little bit of the mathematical background and some motivation for it. This is all but necessary to understand what I did for the summer anyways, so I can't really see any way to avoid it. Then I spoke for a few minutes about what I'd personally done, using the context I had established earlier.
Oh okay I see.
Hm though, if all someone did was grunt work/make plots, than how would he describe what he did to the audience? Surely, the audience probably would not enjoy the gory details of all the gruntwork.
You are learning about what real research is like.
Seriously, people *are* interested in the gory details. Some of the things that people are interested in are:
1) why did you use this particular package or process data in this particular way. What were some of the alternatives and why did you not use them.
2) how did you like that package?
3) was there anything that you discovered or produced that would make life easier for other people doing similar things. (i.e. we spend five weeks doing this, but then we found out that you could do things this easier way) We wrote these scripts, and we posted them onto the web, or we wrote these scripts, it turns out that they are unreusable because ...
Getting out useful plots is a #@$#@$ pain in the rear end, and if you figured out a way of doing it more quickly (or can explain why it can't be done quickly) then that's research.
wouldn't you be proud of being the person who invented the wheel? If you can re discover something good you are in very good company and can expect more rewarding results in future.
They weren't. Also it's unlikely that your mentor invented those ideas. He or she got them from someone else, and part of the point of learning to do research is to be able to say, I got this idea who got it from this other person who got it from this other person.
They really should. I got the idea to do X from person Y, but I was the person that actually sat down in front of the computer and did it. There's a big difference between getting the idea to climb Everest and actually planting the flag.
Learning how to cite and give credit is part of the education of the researcher.
Oh okay, those are good points. I should talk about those then. There were other approaches I tried that didn't quite work out, and I should discuss those (which also means that I don't have to totally throw out several weeks of work, which is somewhat reassuring)
Hm, well, it was just taking equations I could find on the Internet and then recoding them to be usable in Python's Matplotlib. So it wasn't like rediscovering how to project things onto a 2D stereographic projection.
Ah okay. Let's see here - what if what I did didn't produce results yet? The LSST isn't going to do anything for several more years, so the only thing I can say is that I coded a way to project stars on the grid in a different interface.
If you can figure out what didn't work, that's useful. If you can explain to other people what didn't work, that's even more useful.
And that's what 80% of theorists do.
Those are results.
Okay I see. Thanks!
