Dynamics of self-gravitating dust
  • Context: Graduate
  • Thread starter Thread starter tom.stoer
    Dust Dynamics
The discussion revolves around the dynamics of self-gravitating dust within the framework of Newtonian mechanics, exploring the possibility of deriving expanding solutions analogous to those in general relativity (GR). Participants examine the implications of compressible fluid equations, the behavior of test particles in a gravitational field, and the challenges of defining gravitational potential energy in an infinite universe.
  • One participant expresses skepticism about a friend's claim that an expanding solution can be derived from equations for compressible fluid or dust, particularly questioning the validity of free fall for all particles in the cloud.
  • Another participant suggests that the Friedmann equation for an expanding universe can be derived using Newtonian mechanics under certain conditions, though this may involve some handwaving.
  • A participant raises a question about reconciling decreasing density with homogeneity, noting a potential contradiction in the definitions of density at different points in space.
  • A later reply references "Introduction to Modern Cosmology" by Liddle, indicating that Newtonian gravity can yield results similar to GR, but highlights issues with defining potential energy in an infinite universe.
Participants do not reach consensus on the validity of the initial claims regarding free fall and the derivation of expanding solutions. Multiple competing views and uncertainties remain regarding the application of Newtonian mechanics to cosmological models.
Participants note limitations in defining gravitational potential energy in an infinite universe and the potential issues arising from the assumptions made in the derivation of equations. The discussion reflects the complexities of applying Newtonian mechanics to cosmological scenarios.
tom.stoer
I have a problem with the following scenario:
A friend of mine claims that it's possible to start with equations for a compressible fluid or dust and to derive an expanding solution in Newtonian mechanics (!) He claims that this expansion is homogeneous and isotropic (I understand his reasoning) and that all particles in the cloud are in free fall i.e. feel no force (this what I do not believe). His equations for test particles do indeed look homogeneous and isotropic, but I doubt that he can correctly derive free fall.
He claims to be able to derive the motion of a test particle that moves together with the expanding sphere of dust in free fall due to the gravitation of the dust. He does not present the equation for this sphere of dust, but instead he uses a kind of effective equation for a test particle from the very beginning. It's not clear to me how he can bypass the equation for the dust itself.
Instead of presenting his derivation I would like to use a different approach. Start with the e.o.m for the dust, i.e. a kind of Euler equations for a compressible fluid taking into account the gravitation of the dust. If this could be done one finds directly how the flow of dust may look like. In that case the motion of the test particle along with the dust could indeed result in free fall.
First question: is there a proof whether such a scenario as described above is possible or impossible? is there an analogy with an expanding universe (from GR) in the sense of Newtonian mechanics, i.e. an explosion of a matter distribution in space (instead of expansion of space as in GR)?
Second question: is there a simple derivation of the dynamics of a gravitating sphere of dust in Newtonian fluid dynamics? Of course the radius of the sphere shall be infinite in order to achieve an homogeneous and isotropic solution.
Third question: does anybody know how to combine the Euler equations for a fluid with the gravitational energy
[tex]V = \int d^3x \int d^3y \, \frac{\rho(\vec{x},t)\,\rho(\vec{y},t)}{|\vec{x}-\vec{y}|}[/tex]
I think I can answer one of the questions.
You can derive the Friedmann equation for an expanding universe with Newtionion mechanics as long as the universe is flat and no cosmological constant. Just look at the escape velocity of a particle trying to escape the mass/energy of the universe.
Actually, you can derive the Friedmann equations with curvature from Newtionion mechanics. It takes some handwaving, however. See "Introduction to Modern Cosmology" by Liddle.
Thanks.
Starting with a scalar density, how can one satisfy both decreasing density and homogenity?
Sitting at r I see the density
[tex]\rho(\vec{r}, t) = \rho(r, t)[/tex]
Sitting at a different point I see
[tex]\rho(\vec{r}^\prime, t) = \rho(\vec{r} + \vec{dr}, t) = \rho(r, t) + dr_i\,\partial_i\,\rho(r, t)[/tex]
But if the solution shall be homogeneous the second term must vanish and therefore the density must be constant. Where's my mistake?
OK, I checked "Introduction to Modern Cosmology" by Liddle.
It seems to be rather clear. The equations are well defined from the very beginning and it seems that Newtonian gravity does more or less exactly the same as GR does. As the derivation is more or less identical to GR (differential equations do not care about their meaning :-) the problem must be in the very beginning. I guess it's the step where Liddle introduces the total energy of a mass (volume element) m. In an infinite universe with Newtonian gravity this potential energy is ill-defined due to the instantaneous 1/r law.
So I would say that if one skips the technical detail that the whole model is not defined, the results of the model agree with GR :-)
  • · Replies 50 ·
  • · Replies 40 ·
  • · Replies 47 ·
