Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Mechanical Engineering (http://www.physicsforums.com/forumdisplay.php?f=101)
-   -   ANSYS Bending Moments Calculation (http://www.physicsforums.com/showthread.php?t=505251)
dsav Jun8-11 09:40 AM
Dear All,
I have been trying to calculate the bending moment redistribution on continuous, steel fiber reinforced, beams.
The idea is simple, introducing to the ANSYS model elements, with lowered E-modulus, according always to the evolution of the cracking observed on the actual tests.
I tried initially with solid 65 and a 3-d model but this material is not compatible with the bending moment (BM) calculation by ANSYS.
I then created a model with BEAM3 element and obtained the BM diagram (Line element solution).
Here comes the tricky part: when i implement new elements with reduced e-modulus i get the same BM-graph. That is obviously not correct since my beam is a continuous supported beam and thus a moment redistribution must be noticed. (Of course I updated my element table after the 'solve>current LS').
What can I do? How can I make it work?
The best,
DSav
CFDFEAGURU Jun8-11 11:44 AM
Re: ANSYS Bending Moments Calculation
For that type of problem, you should contact your ANSYS re-sellers help desk. Make sure you have your customer ID number.
Thanks
Matt
dsav Jun9-11 01:49 AM
Thanks Matt!
I did. But I thought it was a problem that many more would have dealt with.
DSav
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
