Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Finding the solution to an IVP Problem. Basic Differential Equations problem. (http://www.physicsforums.com/showthread.php?t=506419)
cyturk Jun12-11 07:43 PM
I am trying to solve an IVP problem and I seem to be stuck on it because I am getting an integration that seems very complicated and I think I messed up on it, I have my work so far below.
Find the solution to the IVP
ty^'+7y=2t^2 e^2t, y(1)=7
Is this equation linear? Determine in what interval the solutions exist.
2. Relevant equations
3. The attempt at a solution
http://i.imgur.com/rs1nk.jpg
The image has my work so far, as you can see the integration for (t^7)(2te^2t) is a beast and that is why I think I am wrong so far. Here is the integration answer http://www.wolframalpha.com/input/?i=integrate+%28t^7%29%282te^%282t%29%29.
JJacquelin Jun13-11 01:13 AM
Re: Finding the solution to an IVP Problem. Basic Differential Equations problem.
The primitives of (t^8)exp(2t) are on the form P(x)exp(2t) were P(x) is a 8th degree polynomial.
Derive this function and find the coefficients of the polynomial by indentification with (t^8)exp(2t)
hunt_mat Jun13-11 05:09 AM
You started out very well, and from:
[tex]
\frac{d}{dt}(t^{7}y)=2t^{8}e^{2t}
[/tex]
I think you have made an error, you can do two things: 1) You can do an indefinite integration and add an integration constant and find that constand by using the initial condition or 2) integrate from 1 to t both sides and use Y(1)=7.
HallsofIvy Jun13-11 06:50 AM
Integrate 2t8e2t using integration by parts- 8 times!
cyturk Jun26-11 03:22 PM
Quote:
Quote by HallsofIvy (Post 3354240)
Thanks for everyone else and this is what I ended up doing. It was the correct way of solving the problem even though it was a little bit of a hassle! :)
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
