ODE now made me think about derivatives and partial derivatives
The discussion revolves around understanding the differences between partial derivatives and total derivatives in the context of a function representing a circle in three-dimensional space. The original poster presents a function defined as F(x,y) = C = x^2 + y^2 and questions the implications of using partial derivatives versus total derivatives when considering the relationship between x and y.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the meaning of the partial derivative with respect to x compared to the total derivative, particularly in the context of a function that includes y as a function of x. They discuss how the total derivative accounts for the change in y as x changes, while the partial derivative assumes y remains constant.
Some participants provide insights into how the total derivative reflects the rate of change of the function with respect to x, incorporating the dependency of y on x. There is an ongoing exploration of how these derivatives can be represented graphically, and participants are questioning how to visualize these concepts effectively.
There is an assumption that y is a function of x due to the constraint defined by the equation of the circle. Participants are also considering the implications of this relationship on the derivatives being discussed.
flyingpig
Let's say I have a function for a circle
[tex]x^2 + y^2 = C[/tex] where C is a constant.
Then this is a cylinder with the z-axis.
Now in my ODE book, we would normally define it as
[tex]F(x,y) = C = x^2 + y^2[/tex] as a level surface.
Now my question is about what the partial derivative with respect to x mean as opposed to (single-variable calculus) derivative with respect to x mean. Am I losing anything if I take one derivative over the other?
I should mention that many of these problems assume that F(x,y(x)).
[tex]\frac{\partial F}{\partial x} = 2x[/tex]
[tex]\frac{\partial F}{\partial y} = 2y[/tex]
[tex]\frac{\mathrm{d} F}{\mathrm{d} x} = 2x + 2y\frac{\mathrm{d} y}{\mathrm{d} x} = 0[/tex]
So now my question is, what exactly is this
[tex]2x + 2y\frac{\mathrm{d} y}{\mathrm{d} x} = 0[/tex]
as opposed to
2x
[tex]2x+ 2y\frac{dy}{dx}[/tex]
is the rate of change of the function [itex]f(x, y(x))= x^2+ y(x)^2[/itex]
with respect to x- it measures how fast f(x,y(x)) changes as x changes. Of course that will depend upon exactly how y(x) changes as x changes- and that is what dy/dx tells you.
Suppose y(x)= 3x. Then [itex]d(x^2+ y^2)/dx= 2x+ 2y dy/dx= 2x+ 2y(3)= 2x+ 2(3x)(3)= 20x[/itex].That is exactly the same as if you had replaced y with 3x from the start: [itex]x^2+ (3x)^2= x^2+ 9x^2= 10x^2[/itex] so [itex]df/dx= 20x[/tex][/itex]
I thought that was what the partial derivative with respect to x is
No, the partial derivative of f with respect to x is the rate of change as x change assuming y does not change.
Right.
given a small change in x, dx, the change is x^2 is close to 2xdx and the change in y^2 is close to 2ydy. But dy = (dy/dx)dx.
If y were independent of x then dy/dx would be zero. This would just mean that x can change without a change in y. But the constraint C = x^2 + y^2 tells you that y is a function of x, at least locally.
lavinia said:
Right.
If I were to graph all three of those "derivatives" what would they look like? How do yuo even graph Fx alone?
Actualyl could I get a unit representation?
Say F(x,y) was a position function of time (perhaps x(t) = x and y = y(t))
what would the different derivatives tell me?
  • · Replies 18 ·
  • · Replies 105 ·
13K
