Power consumed in a circuit problem
  • Context: Engineering
  • Thread starter Thread starter reddvoid
    Circuit Power
The discussion revolves around a circuit problem involving power consumption, specifically focusing on how to calculate the power consumed in a network given a total power of 10W. Participants explore various approaches using Ohm's law and discuss the roles of different components, including resistors and voltage sources.
  • Some participants suggest using Ohm's law (V = IR) and the formula for power (P = I²R) to analyze the circuit.
  • One participant calculates that a vertical resistor with 2V across it draws 1A, consuming 2W, leaving 8W for another resistor.
  • Another participant questions the power consumed by the voltage source, noting that it does not dissipate power but can deliver or consume power depending on current direction.
  • There is a claim that the total power delivered by a current source is 12W, leading to confusion about where the remaining power goes since the total power consumed is stated to be 10W.
  • Some participants discuss the concept of energy conservation, stating that energy cannot be created or destroyed and can only be converted to other forms, such as heat in resistors.
  • One participant raises a point about definitions, distinguishing between consuming and storing energy, suggesting that storing energy does not equate to consuming it permanently.
Participants express multiple competing views regarding the roles of the voltage source and the interpretation of power consumption versus storage. The discussion remains unresolved, with no consensus on the definitions or calculations presented.
There are limitations in the assumptions made about the ideal components in the circuit, and the discussion highlights the complexity of analyzing power in circuits with both sources and loads.
reddvoid
power consumed in network is 10W find x. . .[PLAIN]http://images.orkut.com/orkut/photos/OgAAAHYO2Cukar_CMK8JOkLk5qAQfPUr3iky8NDyaOQn9SPEu_FlQbBJgDuwzyeSSGCHJqIrieRrXw7nunQABYmKvvAAm1T1UA4auggZbM0soX2EK5UG6eytpKFa.jpg
You can do it using Ohm's law (V = IR), and Power = I2R
but they've given total power consumed in circuit is 10W
that's what bothering me .
The vertical resistor has 2 volt across it. Thus the vertical resistor draws 1 amp so wattage is 2 watt.
This leaves 8 watt for horizontal resistor.
Watt = I^2*R
So what is correct answer?
Watt = I^2*R
what about the power consumed by voltage source ?
Power = I2* R and this is a perfect voltage source with no resistance.
So, how much power would it dissipate?
it doesn't dissipate any power but it consumes or delivers some power depending on whether the current is entering it's +ve terminal or leaving It's +ve terminal.
The Resistance parallel to the 2V has 1 Amp and uses 2Watts.
The other resistor needs to use the remaining 8 Watts. 2Amps.Answer is B
Answer is B
If one of those two amps supplied by the current source is flowing through the vertical resistor, where does the other amp go?
It must flow INTO the voltage source via its + terminal, making it a power sink. So choice B will make the circuit consume more than 10W !
But you also need to work out either the Voltage and Current sources or the loads but not both.
Sources and loads should cancel each other out.
The power absorbed by the 2V at 1Amp is 2 Watts.
The power from the current source is 6Volts and 2 Amps equals 12 Watts.
10 Watts total for circuit = 12 Watt - 2 Watt
EDIT: This is an example of how ideal components are misleading. If you add some internal resitance then the 2Volt would be a load and a source.
here only current source is delivering power
the two resistors and voltage source are consuming power
so if we take X=2A total power delivered=total power consumed=12W
-------but at x=1.8A
we ll get total power delivered=total power consumed=10W
]]]]]] so answer is NONE [[[[[[[[
Remember that energy can't be created or destroyed. It can be converted to another form like heat from electrical energy.
A power source cannot consume power without converting it to another form, so the energy, except that which is dissipated as heat in the resistors, is still in the circuit .
One way this could happen is if the voltage source was a rechargeable battery. The energy would be converted to chemical energy and could be recovered later as electrical energy.
So, the only power dissipated or consumed is that which goes to heat up the resistors.
we ll get total power delivered=total power consumed=10A
10 watts ?
10 watts ?
sorry its W, my mistake :):)
so,if we consider "the only power dissipated or consumed is that which goes to heat up the resistors (which is 10W here)." but total power produced by current source is 12W
then where is the remaining 2W going . . .
Voltage source is consuming it right?
maybe it is storing it as chemical energy but still it is consuming power right ?
Maybe we have a problem with definitions.
Storing does not mean the same thing as consuming.
Consuming means that energy has left the circuit permanently. Storing means it is still in the circuit and available for future use.
It is just like a charged capacitor. If it is loss-free, it can return as much power to the circuit as was stored in it.
Discuss it with your teacher, but I doubt that you will get much support.
Ok:confused:
  • · Replies 18 ·
  • · Replies 16 ·
