Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Mechanical Engineering (http://www.physicsforums.com/forumdisplay.php?f=101)
-   -   Planetary gear design (http://www.physicsforums.com/showthread.php?t=512900)
zain1 Jul9-11 12:09 AM
planetary gear design
Hello
I want to ask that is it possible to have the number of teeth of sun gear and pinion will be same?
As In my case the ratio is 4:1....outer ring is fixed and sun gear is the input. I want to use three planets.
and if I take 14,16,17 for the sun gear then the condition of (Z1 +Z3)/number of planets should be integer.
but if i take 15 for the sun gear then the number of teeth on planet is also 15 with 45 on ring.....
I want to ask is it right to take 15 teeth for both sun and planet and 45 for ring to get the ratio of 4:1????
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
