Light building the standard model
The discussion revolves around the nature of light, specifically questioning the assertion that light has no mass. Participants explore various aspects of light's behavior, including its momentum, interaction with gravity, and wave-particle duality. The conversation touches on theoretical implications, experimental evidence, and historical context regarding the understanding of light in physics.
  • Some participants argue that light has momentum and is affected by gravity, leading them to conclude that it must have mass.
  • Others challenge this reasoning, stating that momentum and gravitational effects do not necessarily imply mass, and that energy considerations in general relativity provide a different perspective.
  • Several participants mention experimental data that suggests light has no rest mass, with one noting an upper limit on photon mass as extremely small.
  • There is a discussion about the concept of relativistic mass and how it relates to energy, with some asserting that photons cannot have rest mass because it would lead to infinite mass at the speed of light.
  • Some participants express confusion about the transition from classical mechanics to quantum mechanics, questioning how classical principles apply to light and whether they should be discarded in this context.
  • One participant emphasizes that scientific understanding evolves through experimentation and that current theories assume light has no mass based on extensive evidence.
Participants do not reach a consensus on whether light has mass. There are multiple competing views regarding the implications of light's momentum, gravitational effects, and the definitions of mass in different contexts.
Some discussions highlight limitations in classical mechanics when applied to quantum phenomena, suggesting that classical definitions may not adequately describe light's behavior. There are also references to historical experiments that shaped current understanding, but no specific conclusions are drawn about their implications.
elegysix
Something has bothered me for a long time about our model of light: that it has no mass.
Just for a moment, forget what you know about light and let's call it the unknown, X, and suppose we want to model it.
Here's what we know for certain:
X has momentum, as seen by radiation pressure
X is affected by gravity, as seen by gravitational lensing
X can act as a particle and a wave
So we take something with momentum that is affected by gravity and we can easily conclude that it has mass. And since it has mass, we can easily say that it must be a particle... And systems of particles can show wave behavior.
So then we conclude that light is a particle with mass.
How exactly did we come to the conclusion that Light has no mass?
Science news on Phys.org
How did you come to the conclusion that light has mass?
X has momentum, which only means it obeys conservation laws. X is affected by gravity, which only means that it has energy as per general relativity. X acts as a wave/particle, how does one conclude anything about its mass from this? How do you conclude that photons have mass from ANY of those 3 criteria?
You're just taking an elementary knowledge and trying to claim it must generalize to everything else, which is wrong. What it really should be telling you is that momenta, gravity, and wave/particle duality are more complicated than you think.
I guess one way of answering your question is... experimental data. Light is nothing more than a ripple in the electromagnetic field, why should that have mass?
The mass of any object increases if its speed increases to near the speed of light.
At the speed of light an object would have infinite mass, which is not possible.
Hence a photon can not have rest mass.
However photons do have a relativistic mass given by E=mc2.
This is called the mass-energy-equivalence relation.
That is, relativistic mass is seen as equivalent to energy.
Because momentum has been defined as mV in classical mechanics, and only things with mass are affected by gravity, (F=GMm/R^2...). That gives you two different reasons to think it has mass.
Everything physically tangible obeys classical mechanics... but when we look at light and anything on the atomic level, we throw out the logic of classical mechanics. Applying the logic from classical mechanics, it is obvious to me that it has mass. Yet I know that this is not so. How did we decide that classical mechanics did not apply here?
I would like to get at the history of this model, how we came to this conclusion.
an upper limit on photon mass? Why would they try to measure it if they are sure it doesn't exist?
That's not exactly true. The 'universal speed limit', as one might want to put it, is the ~3x10^8m/s speed limit we know of as the speed of light. What that speed is is actually the speed of a massless particle. The photon happens to be the only massless particle we know of at this point, so people typically say speed of light when technically, you should say "speed of a massless particle". The photon could have a mass and it would be so small that the deviation from the "speed of a massless particle" would be so insignificant that it would be completely undetectable in every experiment we've ever done at this point.
This is a major part of what I am questioning. From classical mechanics alone, I see no reason to believe this. We know classical mechanics works. So starting with classical mechanics, How do you figure that these things happen?
No, that is not how momentum is defined in classical mechanics. That is how momentum is defined in a very specific case. Something as simple as angular momentum is not defined like that. Get into classical electrodynamics and you'll see even more complicated forms of momenta. So in general, P = mv is NOT the whole story.
We didn't just decide one day to throw out the logic of classical mechanics. Many many experiments were able to show that classical mechanics just makes no sense at what we now consider the atomic and quantum scale. For example, Rutherford (don't quote me on who actually did this, my memory of physics history is appalling) showed that the atom was in fact, a hard solid object (the proton/nucleus). So classical mechanics makes one assume that maybe electrons and protons are like planets, the electron orbits the proton in the same way the Earth orbits the Sun. Well, one of the problems with that is that accelerating charges radiate away energy. So applying classical mechanics and classical electrodynamics to the atom, the electron should radiate away all its energy and collapse into the proton within a fraction of a second.
Clearly that is not what happens. So classical mechanics is not the way to approach things at the quantum scale. Of course, there are a LOT of other ways to show classical mechanics does not work on the atomic scale, but I wouldn't want to spell them all out.
Because that's how science works. No one is sure about anything. All we can say is that "X theory holds true up to an experimental limit of Y". All our experiments show that the photon has pretty much no mass and we can build our theories safely by assuming it has no mass. If it turns out it DID have mass, the consequences would be so small that it would have almost no bearing on present day physics.
Another example is, like you mentioned, Newton's law of gravitation. We don't actually know for sure that the law goes like [itex]F = {{GMm}\over{r^2}}[/itex]. One could say, well, what if Newton's gravitational law goes like [itex]F = {{GMm}\over{r^{2+\epsilon}}}[/itex] where [itex]\epsilon[/itex] is incredibly small. You could measure the orbits of the planets and be able to put upper or lower limits on what that [itex]\epsilon[/itex] could be. Obviously since we know Newton's law of gravitation works very well, we know it would have to be very close to 0 so that it wouldn't be detectable over all these centuries.
Of course, general relativity already shows us that that form of gravity is not exactly right either, but that's kind of another way of looking at how we talk about theories vs. what our experiments tell us.
That is not even true in classical Newtonian mechanics. Only test particles with mass have a force on them, but classically it doesn't take any force to accelerate a massless particle. The acceleration due to gravity is independent of the mass of the test particle.
That's the scientific method. You have a theory, the theory makes some prediction, so you perform an experiment to test the hypothesis.
So we have measured it over and over with increasing precision, and to the best precision possible it is 0.
"X has momentum, which only means it obeys conservation laws. X is affected by gravity, which only means that it has energy as per general relativity." - Pengwuino
"However photons do have a relativistic mass given by E=mc2." - I Like Serena
If it's true we measure the momentum of light via radiation pressure, does this pressure increase with the energy/ frequency of light? Since light (affected by gravity) has energy as per general relativity, a relativistic mass given by E=mc^2, and energy given by E=hf, could you say that light has a mass proportional to it's frequency given by m=hf/c^2?
Don't think of relativistic mass as actual mass. The momentum of an object increases as it's velocity increases, but its mass (IE it's rest and gravitational mass) do not increase to my knowledge. I believe it is part of how people tend to explain the fact that you can't get to c, because your mass increases. However I think this is inaccurate. If I'm incorrect someone let me know please.
No. Photons (assumed to be massles) do not have relativistic masses either, contrary to what I Like Serena stated. The relativistic mass of a particle is given by [itex]m = \gamma m_0[/itex] where [itex]m_0[/itex] is the rest mass of the particle and [itex]\gamma = {{1}\over{\sqrt{1-{{v^2}\over{c^2}}}}}[/itex]. Photons do not have a rest mass and their velocity is equal to c, so this equation is clearly ill-defined.
The momentum of light is given by the full relativistic energy equation, [itex]E^2 = p^2c^2 + m_0^2c^4[/itex]. Light has no rest mass so the second term on the right hand side is 0 and solving for the momentum, you find it is given by [itex]p = {{E}\over{c}}[/itex]. The energy of a photon is given by [itex]E = \hbar \omega[/itex] where [itex]\omega[/itex] is the angular frequency. So the momenta is propotional to the frequency, but there is no mass to speak of.
Here's what I'd like to see...
solve for the mass by calculating the momentum from radiation pressure.
Take that mass at the speed of light and solve for the trajectory in the vicinity of a planet (non-relativistically, through classical mechanics).
Then check the trajectory against that of current model.
If it doesn't match up, clearly we'd be wrong about assigning a mass to a photon...
If you've got the time and the curiosity, I'd really like to see this done. I've tried over and over again, but I always get stuck on some of the math... :(
elegysix said:
Here's what I'd like to see... solve for the mass by calculating the momentum from radiation pressure.
Take that mass at the speed of light and solve for the trajectory in the vicinity of a planet (non-relativistically, through classical mechanics). Then check the trajectory against that of current model. If it doesn't match up, clearly we'd be wrong about assigning a mass to a photon...
Of course we'd be wrong about assigning a mass to a photon. That's why we DON'T. We instead say that a photon is massless. This happens to be consistent with all known experiments to all known precisions.
That's probably already been done. The easiest comparison would be to compare against the deflection of light given GR's calculation. This is common enough knowledge. Then do the calculation of a massive particle being deflected by the Sun in some 1/r potential.
There are some fairly simple reasons why I expect this won't even accidentally be right considering GRs calculation is independent of the photon's momentum whereas the deflection in this "classical mechanics" calculation would have to depend on the momentum. Of course, GR has been confirmed experimentally.
So how do you calculate the momentum p of an object then? :confused:
I thought you calculate p from [itex]E^2=p^2 c^2 + m_0^2 c^4[/itex] by combining it with [itex]E=m c^2[/itex] and [itex]m = \gamma m_0[/itex].
For low speeds this can be approximated with p=mv.
Since the rest mass of a photon is zero (or insignificant :smile:), the formula [itex]m = \gamma m_0[/itex] breaks down, giving an indeterminate result.
However, for a photon you can calculate the energy from the formula [itex]E = \hbar \omega[/itex].
Afaik, the mass-energy-equivalence relation does not break down.
So a photon has a relativistic mass of m=p/c (classically speaking).
And yes, a photon has to have equivalent mass (classically speaking) for gravity to act on it.
Yes, that's how you calculate the momentum of a particle with some rest mass [itex]m_0[/itex]. It's just instead of the energy given by [itex]E = mc^2 = \gamma m_0 c^2[/itex], the energy is given by [itex]E = \hbar \omega[/itex]. [itex]E = \gamma m_0 c^2[/itex] only works for massive particles. The right hand side of the relativistic energy equation is fine, the left side is the one you tweak for photons (or equivalently you can define the momenta of a photon as [itex]\hbar \omega /c[/itex]).
And yes, you can calculate an "equivalent classical mass", but it's meaningless beyond the one scenario of gravitational pull. Hell, I don't even think it says anything about the actual mass of a photon beyond that because the photon's mass might be irrelevant due to Equivalence.
You can do a quick calculation and find any normal photon has a "mass" 20 orders magnitude higher than the current experimental upper limit.
This wouldn't tell you anything about the mass. Remember, gravitational acceleration is independent of the mass. The trajectory depends only on the initial velocity, not the mass. This experiment would allow you to distinguish between different models of gravity, but not different masses of the test particle.
In any case, since we have measured it's mass to be 0, then clearly we would be wrong about assigning a mass to a photon in any case.
No it doesn't. This is a common fallacy. The acceleration due to gravity is independent of the mass classically.
For a gravitational lens the equivalent mass of a photon is indeed irrelevant.
And I am aware that classical mechanics does not quite predict the right angle, although I seem to recall it is not an order of a magnitude off.
But suppose you make a box containing perfect mirrors containing many photons.
How much would the box weigh?
Doesn't the mass-energy-equivalence relation give you this?
And what kind of quick calculation would find a "mass" 20 orders magnitude higher?
In what context?
Ummm so what you're saying is that the acceleration is given by a=GM/r^2, which accelerates even massless objects? Wouldn't this imply that F=GMm/r^2 is wrong?
No, you can derive the second from the first by substituting F=ma.
Bottom line here for your initial question is simple: the assumption that the photon has [measurable] mass just plain doesn't match observations.
Anyway, that was one of the great triumph's of early physics, the idea that acceleration due to gravity was not dependent on the mass of the dropped object.
I think i meant to say that dividing by m you get the relations
a= F/m=GM/r^2
letting m=0 implies a=inf, GM/r^2=inf, and F=0,
but also you get the relation a=GM/r^2, which contradicts a=inf
but how can we accelerate something without a force? that doesn't seem to make sense.
a= F/m=GM/r^2
That's because photons are not accelerated. The always move at c. Hence one reason why gravity is thought of as a curvature of space and not a force like the other forces.
In what context?
After some discussion with someone else, Einstein (amongst many others), did do the calculation and to first order, the deflection is 1/2 of what it should be.
As for the "mass" calculation, the mass should naively be [itex]m = p/c[/itex]. Figure a 1x10^9 Hz photon or something and you can show the mass is way way above the experimental upper bound.
a= F/m=GM/r^2
You do realize you're going to run into a lot of things that make no sense if you refuse to believe there is a purpose to general relativity, right?
And to preempt one who might ask "Then how does light curve if it's not accelerated", accelerations are basically deviations from what are called 'geodesics' . Since energy/momentum curves space-time, the path a photon would travel in flat-space looks different than it would if there were a sun/planet nearby curving the space-time.
Yes.
Nope. It only implies that it doesn't take any force to accelerate a massless object. Classically this is clear by f=ma.
a= F/m=GM/r^2
Your math is a little off. 0/0 is not infinite, it is undefined.
  • · Replies 17 ·
  • · Replies 26 ·
