Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Time dependent PDEs - mathematical modelling - diffusion equation (http://www.physicsforums.com/showthread.php?t=522187)
Anabelle37 Aug17-11 05:17 AM
Porous membranes are used to separate mixtures in industry, because smaller
compounds permeate through them more easily than larger ones. KnoGas Pty
Ltd are trialling an experimental separation process, using a membrane to sep-
arate compounds A and B: compound A permeates the membrane, while com-
pound B cannot. The ratio of A to B in the original mixture is held constant,
and any compound A that has di used through the membrane is instantly re-
moved for storage when it emerges at the other side.
It is discovered, however, that compound A interacts with the membrane:
during this interaction, some (but not necessarily all) of compound A turns
into a useless by-product. This reaction doesn't a ect the rate of di usion of
compound A, but the permeation process is no longer described by di usion
alone. Importantly for KnoGas, the production rate of compound A { the rate
at which it leaves the membrane { is changed as a result of this reaction.
You have been asked by KnoGas to develop and solve a model for this
process, in order to advise them on
1. how the production rate of compound A changes with time; and
2. how the interaction rate between compound A and the membrane aff ects
this change in the production rate over time.
2. Relevant equations
Diffusion equation: dc/dt=D(d^2c/dx^2) these should be partial derivatives
3. The attempt at a solution
dA/dt = D(d^2A/dx^2) + R(A)
R(A) is the interaction term.
Don't know if i'm going about this the wrong way?
kind of confused by the wording. Please help!
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
