Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Math & Science Software (http://www.physicsforums.com/forumdisplay.php?f=189)
-   -   libsvm problem in make function with windows7 (64 bit) (http://www.physicsforums.com/showthread.php?t=525459)
funyhony Aug29-11 06:53 PM
i tried to run libsvm several times but i failed, i've visualc++ i do this mex -setup
Welcome to mex -setup. This utility will help you set up a default compiler. For a list of supported compilers, see http://www.mathworks.com/support/com...11a/win64.html
Please choose your compiler for building MEX-files:
Would you like mex to locate installed compilers [y]/n? y
Select a compiler: [1] Microsoft Visual C++ 2010 Express in C:\Program Files (x86)\Microsoft Visual Studio 10.0
[0] None
Compiler: 1
Please verify your choices:
Compiler: Microsoft Visual C++ 2010 Express Location: C:\Program Files (x86)\Microsoft Visual Studio 10.0
Are these correct [y]/n? y
*********************************************************************** ** Warning: MEX-files generated using Microsoft Visual C++ 2010 require that Microsoft Visual Studio 2010 run-time libraries be available on the computer they are run on. If you plan to redistribute your MEX-files to other MATLAB users, be sure that they have the run-time libraries. *********************************************************************** **
Trying to update options file: C:\Users\Mero\AppData\Roaming\MathWorks\MATLAB\R2011a\mexopts.bat From template: D:\PROGRA~2\MATLAB\R2011a\bin\win64\mexopts\msvc100freeopts.bat
Done . . .
*********************************************************************** * Warning: The MATLAB C and Fortran API has changed to support MATLAB variables with more than 2^32-1 elements. In the near future you will be required to update your code to utilize the new API. You can find more information about this at: http://www.mathworks.com/support/sol...ution=1-5C27B9 Building with the -largeArrayDims option enables the new API. *********************************************************************** *
>> make
D:\PROGRA~2\MATLAB\R2011A\BIN\MEX.PL: Error: '..\svm.cpp' not found.
??? Error using ==> mex at 208 Unable to complete successfully.
Error in ==> make at 5 mex -O -largeArrayDims -I..\ -c ..\svm.cpp
the problem in make , it doesn't work at all , i don't know what to do to make libsvm toolbox work
please help me
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
