How Does Cutting a Torus with a Mobius Strip Alter Its Geometry?
  • Context: Graduate
  • Thread starter Thread starter addedline8
    mobius strip Torus
The discussion revolves around the geometric implications of cutting a torus with a Möbius strip. Participants explore the scenario of slicing a torus multiple times using the path of a Möbius strip, focusing on the resulting number of pieces and the conditions of the cuts.
  • Exploratory, Technical explanation, Debate/contested
  • One participant describes the torus and Möbius strip, proposing a thought experiment about cutting the torus with the Möbius strip and asks for the maximum number of pieces that can result.
  • Another participant questions whether the knife cuts can overlap, suggesting that if the Möbius strips are confined to the interior of the torus, overlapping cuts may be necessary for separation.
  • A further inquiry is made regarding the size of the Möbius strips and the meaning of "uniform curvature," seeking clarification on how the Möbius strips are constructed in relation to the torus.
Participants express uncertainty about the conditions of the cuts and the properties of the Möbius strips, indicating that there is no consensus on these aspects of the problem.
Limitations include unclear definitions of the Möbius strip's size and curvature, as well as the implications of overlapping cuts on the resulting geometry of the torus.
Individuals interested in geometric topology, mathematical reasoning, and theoretical explorations of shapes may find this discussion relevant.
addedline8
whats
addedline8 said:
Consider the torus, a doughnut-shaped solid that is perfectly circular at each perpendicular cross section, and a Möbius strip, which has a single 180-degree twist and a uniform curvature throughout its length. Suppose a torus is sliced three times by a knife that each time precisely follows the path of such a Möbius strip. What is the maximum number of pieces that can result if the pieces are never moved from their original positions?
Note: Each of the Möbius strips is entirely confined to the interior of the torus.
I don't see the picture. Explain again.
Sorry about that. Here is the attached picture. Thanks for responding.
Are your knife cuts allowed to go over each other?
[Actually, looking at your note, they must be able to- if the strips are all in the interior of the torus then if they weren't you could never separate any pieces].
Are your Mobius strips a set size? (I don't quite understand what you mean by your note on the curvature- do you mean that you just twist the interval around the circle at a constant speed around the Mobius strip to make it, so that they are "uniform" in some sense?)
  • · Replies 30 ·
  • · Replies 35 ·
  • · Replies 22 ·
9K
