Is it possible to have tidal currents in the Earth's molten mantle?
  • Thread starter Thread starter Gannet
    Currents Tidal
The discussion explores the possibility of tidal currents in the Earth's molten mantle, examining the interactions between tidal forces and tectonic plates. Participants consider the implications of tidal friction and energy dissipation in both the oceans and the solid Earth, with a focus on theoretical and conceptual aspects rather than established facts.
  • Some participants propose that tidal effects could create currents in the molten mantle, suggesting that tidal friction with tectonic plates might be greater than that created by the oceans.
  • Others argue that the viscosity of the mantle is too high to permit significant dissipation by currents, though some believe that tidal energy may be dissipated through heating the mantle.
  • A participant emphasizes that the Earth's mantle is primarily solid, capable of plastic flow over geological timescales, and questions the use of the term "molten mantle."
  • There is a discussion about the interpretation of the term "primarily" in relation to tidal energy dissipation, with some challenging its implication that oceanic friction is the main contributor.
  • One participant mentions that the small amount of anelasticity in the mantle could lead to some energy losses, but these are considered minor compared to oceanic tidal effects.
Participants express differing views on the nature of the mantle and the significance of tidal currents within it. There is no consensus on whether tidal currents exist in the molten mantle or the extent of tidal energy dissipation in the solid Earth versus the oceans.
Limitations include the ambiguity surrounding the definitions of "molten mantle" and "primarily," as well as the unresolved nature of tidal energy dissipation mechanisms in both the oceans and the solid Earth.
Gannet
Since the tectonic plates ride on the convection currents in the molten mantle, I was wondering if tidal effects could create currents in the molten mantle.
The reason I am asking I found this http://bowie.gsfc.nasa.gov/ggfc/tides/intro.html"
where it states:
The tidal braking in the Earth's rotation is actually caused primarily by friction in the oceans, where "friction" may refer to any number of physical mechanisms which have yet to be determined definitively. For example, bottom friction, induced by tidal currents flowing across the seabed, various kinds of wave breaking, and scattering of tidal waves into oceanic internal waves are all thought to play a role. For a recent overview of this subject, look up Walter Munk's paper "Once again: once again--tidal friction," published in Progress in Oceanography, vol. 40, pp. 7-36, 1997.
This made me wonder if there tidal currents in the molten mantle that the tidal friction with tectonic plates would be significantly greater than the tidal friction created by the oceans.
The scientists at NASA are very qualified people and I am certain that they considered all possible sources of tidal friction. Therefore, since they said "tidal braking in the Earth's rotation is actually caused primarily by friction in the oceans" that this must be the case otherwise how embarrassing would it be if someone on some forum discovered something that they missed.
Dr_Morbius said:
The scientists at NASA are very qualified people and I am certain that they considered all possible sources of tidal friction...
Thanks for replying. I would hope your statement is true and not just "...the light is better here."
Since the tidal potential deforms the entire earth. It seems to me qualitatively that more of tidal potential would be dissipated in the solid Earth than in the ocean. However, the main stream believes
Most of the tidal energy dissipation is believed to occur in the oceans. It is still not entirely clear whether most of the dissipation occurs in shallow seas or in deep oceans.
from http://www.geo.ucalgary.ca/~wu/Goph681/EarthRotation.pdf"
where it states:
This is not something I claim to know very much about.
With that caveat, it seems to me that the viscosity of the mantle is too high to permit dissipation by currents. However, I believe that some tidal energy is dissipated by heating the mantle.
First things first: What molten mantle? The Earth's mantle is a solid (it supports shear waves) that is capable of plastic flow over geological time spans.
where it states:
You missed the key word "primarily". They did not say "exclusively".
The key problem in your reasoning is your use of the term "molten mantle". Over very long time spans (geological time) the mantle appears to be plastic. Over very short time spans such as those resulting from tidal interactions, the mantle is better modeled as an elasto-rigid body with a small degree of anelasticity.
Just as the oceans are subject to tides from the Moon and the Sun (and to a lesser extent the other planets), so is the Earth itself. The same tidal forces that result in the ocean tides also affect the Earth as a whole. Google the terms "Earth tides" and "solid body tides" for more. The Earth tides are for the most part loss-free because the Earth as a whole is mostly elastic on the time scales of the tides (hours to decades). The small amount of anelasticity in the mantle will lead to some losses, but these are small compared to those resulting from the ocean tides.
Thank you Billiards & D H for your comments
From Billiards
...it seems to me that the viscosity of the mantle is too high to permit dissipation by currents. However, I believe that some tidal energy is dissipated by heating the mantle.
The post-glacial bounce in 11,000 years indicates to me though highly viscous that flow does exist. Also, tidal heating to me indicate friction which indicate that there is an opposing force to movement. Maybe the solid Earth tidal bulging is inducing that movement.
From D H
I know it is not exclusively, I was challengining the word "primarily" which in my terminology means the #1 contributor. I have not found any paper yet that substantiate that claim.
  • · Replies 33 ·
20K
10K
  • · Replies 21 ·
