Modular arithmetic question about functions
  • Context: Undergrad
  • Thread starter Thread starter elegysix
    Arithmetic Functions
This discussion confirms that modular arithmetic can be extended to functions, specifically through the concept of quotient rings. The participants establish that defining G(x) = R(x) mod(f(x)) is valid, with R, G, and f being functions of x. They reference the ring of continuous functions on [0,1] and the creation of finite fields using irreducible polynomials. The example of complex numbers is provided, illustrating how polynomials can be reduced modulo x² + 1, leading to the identification of [x] as a square root of [-1].
  • Understanding of modular arithmetic principles
  • Familiarity with abstract algebra concepts
  • Knowledge of polynomial functions and equivalence relations
  • Basic comprehension of finite fields and their construction
  • Study the properties of quotient rings in abstract algebra
  • Learn about the construction of finite fields using irreducible polynomials
  • Explore the relationship between polynomials and complex numbers in modular arithmetic
  • Investigate applications of modular arithmetic in cryptography and coding theory
Mathematicians, students of abstract algebra, and anyone interested in the applications of modular arithmetic in advanced mathematics and theoretical computer science.
elegysix
Hello, I'm new to modular arithmetic, but I was wondering -
Given that
b = R mod(n) where b,R, and n are all integers
Is it plausible to consider
G(x) = R(x) mod(f(x)) with G,R,f all functions of x?
Has this been done or does this not even make sense?
If its been done, what is it called?
If it doesn't work, could you explain a little?
thanks :D
Yes, it does make sense. Have you studied abstract algebra yet? Modular arithmetic is a special case of quotient objects, in this case a quotient ring. On http://en.wikipedia.org/wiki/Quotient_ring" they have some good examples involving polynomials and smooth functions.
For another example, let [itex]R := \{f \in C[0,1] : f \quad \text{is continuous} \}[/itex] be the ring of continuous real-valued functions defined on [0,1]. Given [itex]f \in R[/itex] we can define an equivalence relation by g~h iff [itex]g(x) - h(x) =a(x)f(x)[/itex] for some function [itex]a(x) \in R[/itex]. Another way to write this would be g(x) = h(x) mod (f(x))
not only is it possible, but in fact, it's one of the ways in which finite fields are created.
normally, what one does, is first create the integers mod p, where p is a prime.
then one considers Zp[x], the set of all polynomials with coefficients in Zp (integers mod p).
and THEN, one picks an "irreducible" polynomial (for our purposes, this just means "no factoring possible"), say g(x), and considers the polynomials "mod g(x)".
doing that, gives a finite field, which is surprising, because it's not immediately intuitive that identifying a certain subset of the infinite number of polynomials, gives you such a small (finite) set of "remainders".
one surprisingly familar example of a set of functions (mod f(x)) is the complex numbers. first, you take the set of all real polynomials, R[x].
then, you "mod x2 + 1". that is, you declare p(x) to be equivalent to q(x) if and only if:
p(x) = q(x) + (x2+1)k(x)
we can write [p(x)] for the equivalence class of p(x). now look what happens with [x]:
[x]2 + [1] = [x2+ 1] = [0]
(since x2+1 = 0 + (x2+1)(1), here "q(x)" is 0, and "k(x)" is 1).
this means that [x]2 = -[1] = [-1].
this means that ("mod x2 + 1") [x] is a square root of [-1].
so we have (there's some technical details I'm glossing over) the bijection:
a+bi <---> [a+bx] = [a][1] + [x], that is [x] acts "just like" i.
  • · Replies 26 ·
