Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Introductory Physics Homework (http://www.physicsforums.com/forumdisplay.php?f=153)
-   -   Emptying pressurized tank (http://www.physicsforums.com/showthread.php?t=551183)
fizicks101 Nov16-11 03:44 PM
Problem Statement:
A water tank (Diameter=10m) is pressurized with a gas at 20MPa. 15m below the surface of the water in the tank, is an exit pipe (Diameter=0.4m, area=A2) to a second pressurized tank of 16MPa. What is the maximum flow rate delivered to the second tank?
I'm not sure what I'm missing here. I used Bernoulli's to solve for V2 (at the outlet pipe) by setting V1 to zero(b/c area of the water surface >> area of exit pipe cross section). I then solved for the mass flow rate (mdot=rho*A2*V2).
V2=sqrt((2/rho)(P1-P2-z*rho*g)),
Any suggestions?
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
