Why magnets attract or repel each other
  • Context: Graduate
  • Thread starter Thread starter hushai1
    Magnets Repel
This discussion focuses on the microscopic mechanisms behind the attraction and repulsion of magnets, specifically examining the role of electron spin and orbital rotations. It highlights that magnetic forces, represented by the equation F=qv x B, do not perform work in the traditional sense, yet still result in attraction or repulsion due to the non-uniform magnetic fields near the poles of magnets. The interaction between a tiny current loop and the magnetic field of another magnet is analyzed, revealing that the radial components of the magnetic field influence the forces acting on the current loop.
  • Understanding of electron spin and orbital motion
  • Familiarity with the concept of magnetic moments
  • Knowledge of the Lorentz force equation (F=qv x B)
  • Basic principles of magnetic fields and their non-uniformity
  • Research the effects of non-uniform magnetic fields on current loops
  • Explore the concept of magnetic moments in detail
  • Study the Lorentz force in various magnetic field configurations
  • Investigate the quantum mechanics behind electron behavior in magnetic fields
Physics students, educators, and anyone interested in the fundamental principles of magnetism and electromagnetic theory.
hushai1
I would like to understand at a microscopic level why magnets attract or repel each other. I understand that there are tiny loops of currents caused by the spin and orbital rotations of electrons, that there are magnetic moments, but I don't understand why magnets attract. How is the magnetic force (F=qv x B) acting? What is doing the work since magnetic forces are not doing any work? Thank you
Consider one of the magnets (1) to be a tiny current loop, and ask how it will be influenced by the magnetic field of the other magnet (2). The force on each moving charge in the current loop is e v x B. At opposite sides of the loop the v's are equal and opposite, so in a uniform B field the force averages out to zero.
But near the pole of magnet 2 the B field is not uniform. Near the North pole the lines of B will be diverging, while near the South pole they will be converging. That means the circular loop does not just see a B field perpendicular to its plane, it also sees an additional radial component to the B field pointing outward (or inward). Since v is tangential and B is radial, v x B will be perpendicular to the plane of the loop, and the loop will be attracted (or repelled).
Thank you for your answer. I think it is a good answer. I don't understand however, why, if magnetic forces don't work, there is still some work done since one magnet is able to attract another magnet. Thank you.
  • · Replies 32 ·
  • · Replies 35 ·
