Using a double angle formula with Snell's Law
The problem involves a light ray transitioning from air to glass, requiring the determination of the angle of incidence when the angle of refraction is half of that angle. The context is rooted in optics, specifically applying Snell's Law and double angle formulas.
  • Participants discuss the application of the double angle formula within Snell's Law, questioning how to manipulate the equations to find the angle of incidence.
The discussion is active with various attempts to clarify the application of Snell's Law and the double angle formula. Some participants provide equations and suggest steps, while others express confusion and seek further clarification on the process.
There are indications of confusion regarding the correct application of Snell's Law and the double angle formula, with some participants questioning the validity of their equations and assumptions about the angles involved.
smeiste
A light ray is incident from air onto a glass surface with an index of refraction n = 1.56. Find the angle of incidence for which the corresponding angle of refraction is one-half the angle of incidence. Both angles are defined with the normal to the surface.
n = sin a1/sin a2 (Snell's Law)
sin(a + b) = (sin a x cos b) + (cos a x sinb)
sin(2a) = 2 sin a cos a
Somehow you plug in the double angle formula into snells law. but I don't understand how this is a down. a breakdown of the equations used to solve problem would be extremely helpful :)
The angle of incidence is 2a, the angle of refraction is a. Plug into Snell's law.
ehild
but then how do you solve for a?
Show your equation.
ehild
sin(a)/sin(2a) = 1.56
What happens if you apply the sine double angle formula here?
Your equation is actually incorrect. by Snell's formula,
sin a = 1.56Apply the duble angle formula to sin (2a) to get 2sin(a)cos(a). since a does not equal an integral multiple of pi, you can divide out sin(a). From there, you can find that cos(a) = 0.321
Use the inverse of cosine function to solve for a = 71.306 degrees.
if sin a = 1.56, how do you apply the double angle formula?
Snell's Law:
[tex]\frac{sin(\theta 1)}{sin(\theta 2)} = \frac{v1}{v2} = \frac{n2}{n1}[/tex]
im so confused.. could someone just show the steps on how to solve it? i think much better in equations than words.
Take Snell's law as I wrote it above (You can ignore the velocity ratio, I only included it for completeness. It's not needed for this problem). Substitute the given values for the angles and indexes of refraction. What do you get?
isnt that what i wrote before? sin a/sin 2a = 1.56/1.
sorry, i see. sin2a/sina = 1.56/1
ah ha! so sin 2a = 2sinacosa and the sins cancel out, giving you a final equation of cos a = 0.78. thanks very much everyone!
32K
