Is Dark Matter Really Necessary for Explaining Galaxy Rotation Curves?
The discussion revolves around the necessity of dark matter in explaining galaxy rotation curves, exploring alternative theories and models that challenge the conventional understanding of gravity and cosmology. Participants examine gravitational theories, modifications to general relativity, and the implications of these models on observed phenomena such as galaxy rotation and gravitational lensing.
  • Some participants reference J. W. Moffat's work, which proposes a modification of Newtonian gravity through a variable gravitational constant that could explain galaxy rotation curves without invoking dark matter.
  • One participant expresses skepticism about Moffat's model, questioning its implications for planetary orbits and the flatness problem of spacetime curvature.
  • Another participant suggests that while Moffat's model could fit observed phenomena, it raises questions about the justification for a variable gravitational constant and whether it could merely be a curve fit for dark matter.
  • Concerns are raised regarding the lack of direct observations of non-baryonic matter and the implications of requiring a significant amount of such matter to explain cosmic phenomena.
  • Some participants highlight the work of Moffat, Mannheim, and Milgrom-Bekenstein as examples of alternative theories that eliminate the need for dark matter, while noting the challenges these theories face in explaining the distribution of matter in galaxies.
  • One participant advocates for a model based on zero-point energy (ZPE) fields, arguing that it can account for gravitational effects without the need for dark matter, suggesting that the visible matter and its interactions with these fields are sufficient.
Participants express a range of views, with no consensus reached. Some support alternative theories to dark matter, while others remain skeptical of their validity and implications. The discussion reflects ongoing debates about the nature of gravity and the existence of dark matter.
Participants note limitations in the current understanding of gravitational theories, including the need for further exploration of the implications of a variable gravitational constant and the challenges in observing non-baryonic matter. The discussion highlights the complexity of reconciling different models with observational data.
marcus
Dearly Missed
Gravitational Theory, Galaxy Rotation Curves and Cosmology without Dark Matter
J. W. Moffat
http://arxiv.org/abs/astro-ph/0412195
"Einstein gravity coupled to a massive skew symmetric field [tex]F_{\mu\nu\lambda}[/tex] leads to an acceleration law that modifies the Newtonian law of attraction between particles. We use a framework of non-perturbative renormalization group equations as well as observational input to characterize special renormalization group trajectories to allow for the running of the effective gravitational coupling G and the coupling of the skew field to matter. The latter lead to an increase of Newton's constant at large galactic and cosmological distances. For weak fields a fit to the flat rotation curves of galaxies is obtained in terms of the mass (mass-to-light ratio M/L) of galaxies. The fits assume that the galaxies are not dominated by exotic dark matter and that the effective gravitational constant G runs with distance scale. The equations of motion for test particles yield predictions for the solar system and the binary pulsar PSR 1913+16 that agree with the observations. The gravitational lensing of clusters of galaxies can be explained without exotic dark matter. An FLRW cosmological model with an effective G=G(t) running with time can lead to consistent fits to cosmological data without assuming the existence of exotic cold dark matter."
31 pages, 20 figures
many of the figures show galaxy rotation curve fits
Astronomy news on Phys.org
I will turn you to the dark side of the force (polarized ZPE fields as the source of gravitation and inertia). :-p I truly wish I had the math skills to express the effects I see in my thought experiments with this model. As a VERY crude analogy, imagine a bunch of little bar magnets thrown on a slippery table top. They will immediately clump in a way that represents the lowest potential energy state acheivable from that initial state. (less suspense, more closure, in a sociological analogy) I believe the ZPE fields do this as well, and the attraction expressed in the binding of the lowest potential energy state is what we call gravity.
I'm not comfortable with Moffat's explanation. Unless I made an OOM error, the effects he describes would have measurable effects on planetary orbits within our solar system. Futhermore, I do not see how it addresses the resulting flatness problem of spacetime curvature.
I cannot claim to understand this paper, but it appears that G=Go within the solar system but runs up to G=6Go at larger scales, so that planet trajectories are not affected, but the amount of dark matter is replaced by a variable G.
So it appears that the introduction of variability in distance and time to the gravitational constant plus non-symetric gravity theory can fit all observed phenomena including a flat spacetime curvature and gravitational lensing.
So my question is, what gives us the right to make G variable? Is it not possible that the variable G is just a curve fit to actual Dark Matter. Is there some other process that could make G variable. Is there some way to observe if that is true. Is the theory falsifiable or just a model?
I quess that Occums razor applies. Both invisible energy and matter, and a variable G, can explain the data. But invisibility is preferred to variability.
Richard
Agreed yanniru. It does appear local solar system dynamics are not distinguishable from GR predictions under the NGT model. I'm curious why no mention was made of the pioneer anomaly. It was also unclear how combining GR with a skew symmetric rank 3 tensor field invoking a 'fifth force' coupling constant produces a simpler gravitational theory. The variance of G over time was intriguing, yet unexplained. G is initially low and remains constant for about 10,000 years, then suddenly climbs to the present, much higher value by the time the universe is 1,000,000 years old. The absence of an explanation for this phenomenon, it looks like hand tuning to get a .04 baryonic density in the primordial universe and a .24 baryonic density after 1,000,000 years. That was a bit hard to swallow.
When the current theory has issues, everything is on the table.
Invisible matter in and of itself, isn't much of a theoretical stretch. Requiring 80%+ of all matter in the universe to be non-baryonic, despite the fact that there is not yet a single direct observation of non-baryonic matter, is a stretch. If the stuff makes up so much of all matter, one needs a pretty good reason for explaining why no one has ever come across a chunk of the stuff.
Moffat, Mannheim, and Milgrom-Bekenstein all illustate that it is possible to devise modifications of GR and more specifically of gravity, which eliminate the vast majority of the implication of dark matter. Indeed, there are at least three similar, but not identical ways, to do so.
Moreover, these M^3 scholars also illustrate an additional limitation on any viable CDM theory. Not only must it find non-baryonic matter not yet observed to account for the vast majority of the matter in the universe, it most also explain why the distribution of that matter is so tightly fine tuned to the visible light in the galaxies observed, so as to fit M^3 predictions. In a CDM context, this has to be done more or less entirely through the galaxy formation process, as CDM interacts only through standard GR gravity. A satisfactory and coherent theory to explain the incredible coincidence of galaxy formation that distributed CDM in this way has not emerged to my knowledge.
A G constant that runs with time is certainly the most worrisome aspect of the Moffat approach, but there is a very well documented phenomena out there and CDM as a solution has serious issues.
This is where my ZPE model shines. There is no need to invoke special distributions of CDM. The visible matter, gas and dust that we observe (plus any dark baryonic matter that we can't sense easily) are sufficient to cause the gravitational effects that we see, like cluster binding and lensing. Masses polarize the ZPE EM fields, and the local interaction of masses with the polarized vacuum fields is gravitation. Space-time in this model is flat, and gravitational lensing is a purely optical effect of EM waves propagating through densified polarized EM vacuum fields. The concept of photons following geodesics in space-time is eliminated. GR's space-time curvature is a great mathematical approximation of gravitation in simple systems, like our solar system, but it breaks down on galactic scales, which is why CDM has to be invoked to keep the standard model chugging along.
  • · Replies 32 ·
  • · Replies 24 ·
