Why can AM radio waves travel over mountains while FM signals cannot?
The discussion revolves around the differences in propagation characteristics between AM and FM radio waves, particularly in the context of how AM signals can travel over mountains while FM signals struggle. Participants explore the effects of frequency, atmospheric conditions, and interference on signal reception.
  • Some participants suggest that AM radio waves are transmitted at lower frequencies, which are better at navigating around obstacles and can be reflected by the ionosphere, enhancing their range.
  • Others argue that FM radio waves, typically transmitted at higher frequencies, do not reflect off the ionosphere and are less capable of penetrating or going around objects.
  • A participant questions whether the ionosphere's reflection affects AM signal quality at night, proposing that stations might adjust their signals to compensate for this issue.
  • Concerns are raised about the interference caused by sky waves reflecting off the ionosphere at night, leading to challenges in reception and quality due to co-channel transmissions from distant stations.
  • One participant elaborates on the potential solutions to multipath interference, suggesting a network of low-power transmitters could mitigate issues but noting the limitations of available frequency slots in the MF bands.
  • There is mention of the difficulty in designing antennas that can effectively suppress sky wave reception, complicating the situation further.
  • A participant reflects on the impracticality of re-engineering the MF bands for better digital transmission, citing the limited spectrum and the challenges of international agreement.
  • It is noted that the ionosphere's behavior changes between day and night, affecting signal absorption and reflection, which contributes to the differences in reception quality at different times.
Participants express multiple competing views regarding the propagation characteristics of AM and FM signals, particularly in relation to the ionosphere and interference issues. The discussion remains unresolved with no consensus reached on the best solutions or explanations.
The discussion highlights limitations related to the available spectrum for MF bands and the complexities of interference management, which are not fully resolved within the conversation.
Haftred
I'm curious why can AM radio waves be heard on the other side of a mountain from where they are propogated and FM not?
Thanks
Science news on Phys.org
The 'mountain' phenomenon is not really an AM/FM thing. It's just that AM tends to be transmitted on lower frequencies, that are better at going around objects, and happen to be (sometimes) reflected back to Earth by an upper layer of the atmosphere (the ionosphere).
FM is more usually transmitted on higher frequencies, and these are not so good at penetrating or going aroung objects, and (usually) pass straight through the ionosphere without reflection.
Is the reflection off the ionosphere why AM signals do not come in as well at night as during the day? If so can the stations somehow change the signal to compensate.
The reflection off the ionosphere is a real problem for which there's no good solution.
It allows (co-channel) transmissions from distant stations to get into the service area at night so that reception is only reasonable at short distances from the transmitter. In addition, the sky wave from a transmitter (reflected off the ionosphere) can bounce back and interfere with the direct, ground wave where the signal strengths are near equal and give severe 'fading' and distortion.
The only possible way to deal with multipath interference like that is to use a network of really low power transmitters, whose service areas are so small that the difference in level between ground wave and sky wave is high enough to reduce the interference. The sky wave has to make a total trip of several hundred km so the interfering signal will be very low compared with the ground wave signal at a distance of a few tens of km. The same strategy can help with co-channel interference but such a system needs a lot of different channels to be available so that a network can be set up which is similar to that for TV and VHF radio. There are not enough frequency slots for this in the MF bands (with only about 1Mz of spectrum space to play with ) to allow good coverage- certainly not in a densely populated country like the UK.
It is not helped by the fact that it's pretty well impossible (v. expensive at least) to design transmitting and receiving antennas that can 'point low enough' to suppress transmission and reception of the sky wave.
It must be true to say that an appropriate system of digital transmissions, using the same frequency slot, would work a lot better but that would require an impossible amount of international agreement and re-engineering. The fact is, though, that the available spectrum is very small and with such low capacity, it's hardly worth the bother of re-engineering the mf bands. Compare that available 1mHz of spectrum space at MF with the 10Mb data streams on many Broadband connections to get an idea of how useful it would be. Of course, when the bomb drops, we may be restricted to using all the old fashioned comms frequencies again.
OH, yes - and the ionosphere is much lower during the day (Sun's radiation) and the sky waves are absorbed in the more dense ionised layers. This is why it's not a problem in the day. Soon after sunset, the ions in the lower layers re-combine because the molecules are closer together and only the higher less lossy layers are available.
Thanks Sophie for the quick and information filled response.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 68 ·
