What is the meaning behind the Casi.Voy equation?
  • Context: Graduate
  • Thread starter Thread starter MUKAY
The discussion revolves around the interpretation of an equation attributed to "Casi.Voy," which appears to connect concepts from electromagnetism and gravitation. Participants analyze the equation's structure, its components, and potential implications, with a focus on its theoretical significance and the context of its discovery.
  • One participant found an old equation that resembles Coulomb's law but includes various constants and terms that raise questions about its meaning.
  • Some participants argue that the equation contains too many arbitrary constants to be significant, while others suggest it might indicate a relationship between electromagnetism and gravitation.
  • There is a discussion about the dimensional consistency of the equation, with some noting that certain terms cancel out.
  • One participant speculates that the term involving \(\sqrt{2.5}\) could relate to volume ratios or densities, while another suggests it might indicate a connection to Planck mass.
  • Another viewpoint critiques the equation as mere numerology, lacking a coherent explanation for the relationships between the constants involved.
  • One participant proposes that the author may have had insights into Planck mass and its implications for micro black holes, suggesting a deeper theoretical context.
Participants express a range of opinions, with some finding potential significance in the equation and others dismissing it as lacking foundational physics. No consensus is reached regarding its validity or implications.
Participants note that the equation's formatting affects readability, and there are unresolved questions about the meaning of certain terms, particularly the role of the number 2.5 and the implications of the constants involved.
MUKAY
In Summer 2010 I was traveling through southern Poland and Slovakia.
In the attic of some old house, I found a pile of papers filled with
notes and dated 1945. They are hardly readable - the Author used
almost only abbreviations in Latin, Cyrillic and Hebrew alphabets.
There is a signature: "Casi.Voy" (with cyrillic). There are a few
equations, and this was the only one I was able to fully decypher:
1/(4πε_0 ) e^2/r^2 =G (((2cℏG^(-1))^1/2 )/(4/3 π (√(2.5))^3 ))^2/r^2
would anyone try to interpret it?
Well I'm not a Phd or anything but it looks like its got too many arbitrary constants in it to be anything earth-shattering. Just my 2 cents though I am still an undergrad physics major.
1. The way you formatted the equation it is completely unreadable, please try to use LaTeX (as described here).
2. There are not many arbitrary constants in the equation - G, c, e, [itex]\hbar[/itex], [itex]\epsilon_0[/itex] and [itex]\pi[/itex] have a rather obvious meaning. Only 2.5 looks strange (and apparently is a part of a formula for sphere volume).
Here is an attempt to TeXify the equation:
[tex] \frac{1}{4 \pi \varepsilon_0 } \frac{e^2}{r^2} = G\frac{\left(\frac{\sqrt{\frac{2 c \hbar}{G}}} {\frac{4}{3}\pi (2.5)^{\frac{3}{2}}} \right)^2 } {r^2}[/tex]
r2 cancels out.
I can't read pdf version, I get some error message.
Here's the correct version as in the original. Thanks for TeXifying jhae2.718!
[tex]\frac{1}{4 \pi \epsilon_0} \frac{e^2}{r^2} = G \frac{ (\frac{\sqrt{2 c \hbar G^{-1}}} {\frac{4}{3} \pi (\sqrt{2.5})^3 })^2}{r^2}[/tex]
The meaning of left hand side is quite obvious as BishopUser noted - it's Coulomb's interaction between two electrons. The right hand side is rather strange - it seems a bit like gravitational interaction between masses of some kind.
At least looks like units are consistent.
Note that r2 and G cancel out.
[tex]\frac{1}{4 \pi \epsilon_0} \frac{e^2}{r^2} = G \frac{ \left(\frac{\sqrt{2 c \hbar G^{-1}}} {\frac{4}{3} \pi \left(\sqrt{2.5} \right)^3 } \right)^2}{r^2}[/tex]
Hmmm. Yes, as Borek points out it is dimensionally correct.
The [itex]\sqrt{2 c \hbar G^{-1}}[/itex] has units of mass, as expected. But mass of what? Notice there are no variables in the term. Everything is a constant. And the term contains both the gravitational constant and Planck's constant? weird.
The [itex]\frac{4}{3} \pi \left(\sqrt{2.5} \right)^3[/itex] seems to be a ratio of volumes of some kind -- Like the ratio of the volume of a sphere of radius [itex]r[/itex] per volume of a cube with a length of [itex]\frac{r}{\sqrt{2.5}}[/itex]. Or instead of a cube, maybe the 2.5 has something to do with the shape of some sort of pyramid or something -- something with flat faces so things like pi don't come in.
Or perhaps, the [itex]\frac{4}{3} \pi \left(\sqrt{2.5} \right)^3[/itex] might be a ratio of densities, such as the density of some shape with straight faces per density of a sphere containing the same mass.
I can only speculate.
The form of this equation suggests, that author was thinking about connections between electromagnetism (or at least electrostatics) and gravitation. As long as I understand, we don't have any "standard and official" theory combining those kinds of interactions, but we have a number of more or less interesting (or even crazy) attempts to create such - many of them "homemade".
I find this particular equation so interesting, not only because I found it written among old, notes of unknown origin, but because it connects electromagnetism with gravitation in a quantitative manner (gives a "mass equivalent" of a unit charge).
I really wonder if there's something to it.
Mulkay, it sounds like you are trying to convince us that they're is something to it.
There is not.
First, this is just numerology - attempting to relate different numbers together. There is no "something" yet for there to be "to it". That would require some sort of explanation as to why these numbers are related.
Second, the person who wrote this doesn't know the most elementary physics, or they would have noticed that many of the terms they wrote down cancelled.
Finally, when you complete the path of cancellations, and replace the ε and c with μ (which has the numeric value of 4π x 10), you will be left with an hbar, and a pile of algebra involving numbers. I can always take a single number and represent it as a pile of algebra.
Sorry.
Hi.
Term [itex]\sqrt{\hbar c /G}[/itex] is Planck mass:
http://en.wikipedia.org/wiki/Planck_mass
Author related Planck mass to electrostatic Coulomb force. Planck mass is the mass of micro black hole: it evaporates, then gravitationally condenses back to micro black hole, then it Hawking-evaporates again and so on. But wait, isn't it elementary particle, being so small? It can't blow apart, can it? Yes it can. How? At Planck length usual notions of continuous space-time make no longer any sense. Space-time becomes grained. Particles become black holes falling in and out of singularity. It's definitely some new physics there at Planck scale.
So author knew something about Planck mass. The meaning of term [itex]4 \pi {\sqrt{2.5}}^3 /3[/itex] is beyond me: it is obviously of a form of a volume of sphere, as already noticed earlier.
So the author was young Hawking is our only possible conclusion, I guess, or at least Hawking's previous incarnation :D
Cheers.
Hi.
How come the number of MUKAY's posts reported below his nick in his last post a bit above says: 0?
Cheers.
  • · Replies 23 ·
9K
  • · Replies 0 ·
10K
