What Happens to Charge When Capacitor Plate Separation Doubles?
When the separation between the plates of a parallel plate capacitor is doubled while maintaining a constant potential difference, the charge on the plates is halved. This conclusion is derived from the relationship defined by the equations CV=Q and C=εoA/2d. The capacitance C is inversely proportional to the distance d, indicating that an increase in separation results in a decrease in charge. The initial confusion regarding the answer key was clarified, confirming that the charge does not double but rather is cut in half.
  • Understanding of capacitor fundamentals, specifically parallel plate capacitors.
  • Familiarity with the relationship between capacitance, charge, and voltage (CV=Q).
  • Knowledge of the formula for capacitance: C=εoA/d.
  • Basic grasp of electric fields and potential difference in capacitors.
  • Review the derivation of capacitance for parallel plate capacitors.
  • Explore the effects of varying potential difference on charge in capacitors.
  • Learn about energy stored in capacitors and its relation to charge and voltage.
  • Investigate real-world applications of capacitors in electronic circuits.
Students studying physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to capacitors and charge behavior.
physgrl
If the separation between the plates of a parallel plate capacitor is doubled and the potential difference is held constant by a battery, the magnitude of the charge on the plates will:
*a. double
b. quadruple
c. be cut in half
d. not change
CV=Q
C=εoA/2d
CV=Q
C proportional to Q
εoA/2d proportional to Q
1/d proportional to Q
now if the separation d is doubled the charge Q should be cut in half instead of doubled (as the answer key says) right? so have I made a mistake? Is it supposed to be done differently?
Hi physgrl! :smile:
You are right and the answer key is wrong.
Btw, I have a different formula for the capacitance of 2 parallel plates.
It's ##C={\epsilon A \over d}##, as you can see on the wiki page: http://en.wikipedia.org/wiki/Capacitance
But that does not change your line of reasoning, which is correct.
ohh yeah the 1/2 was a mistake...thanks
  • · Replies 18 ·
