Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Classical Physics (http://www.physicsforums.com/forumdisplay.php?f=61)
-   -   Proof for la grangian (http://www.physicsforums.com/showthread.php?t=574400)
georg gill Feb5-12 03:51 AM
proof for la grangian
As this thread implies i wanted to try to prove ideal gas equation pV=vnRT
where T is tempearture p is pressure n is mole V is volume and R is gas constant
and then I found that I had to prove la grangian
What I wonder about is given in thread here
http://www.physicsforums.com/showthread.php?t=574248
In the end of the thread it is said that someone her might be able to help me with a suitable textbook. Is that possible?
Studiot Feb5-12 05:28 AM
Re: proof for la grangian
Hello Georg,
As with strangerep in the other thread you started I am not sure what you are attempting, but you should look up the Joule experiment and the Joule-Thompson experiment.
They proved experimentally that the so called internal pressure of an ideal gas is zero.
This provides an alternative definition of an ideal gas as a gas with
[tex]{\left( {\frac{{\partial U}}{{\partial V}}} \right)_T} = 0[/tex]
You can use this plus Boyle's law to derive PV=NRT.
The following thermodynamic relation is also useful. this relates to all substances, not only ideal gasses.
[tex]{\left( {\frac{{\partial U}}{{\partial V}}} \right)_T} + P = T{\left( {\frac{{\partial P}}{{\partial T}}} \right)_V}[/tex]
By the way did you see my answer in your other thread about reversibility?
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
