Momentum and Newton's Gravitation force question (2 stars)
The discussion revolves around a problem in gravitational physics, specifically focusing on the momentum of a star influenced by another star's gravitational force. The original poster presents initial conditions, including masses, velocities, and positions of two stars, and seeks to calculate the momentum of the first star after a specified time interval using the momentum principle and Newton's gravitational law.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Newton's gravitational force equation and the momentum principle. There are attempts to calculate the distance between the two stars and the gravitational force acting on the first star. Questions arise regarding the correctness of the distance calculation and the expression of net force as a vector.
Some participants have provided tips on calculating the distance and expressing force as a vector. There is ongoing exploration of the gravitational force's magnitude and direction, with participants questioning their calculations and seeking clarification on vector properties.
Participants note discrepancies in distance calculations and the significance of gravitational force over the time interval. There is an emphasis on ensuring that the net force is expressed correctly as a vector, which is critical for determining the resulting momentum.
physics1311
At t = 0 a star of mass 5.0×1030 kg has velocity < 6.0×10^4, 7.0×10^4, -7.0×10^4 > m/s and is located at < 1.00×10^12, -4.00×10^12, 4.00×10^12 > m relative to the center of a cluster of stars. There is only one nearby star that exerts a significant force on the first star. The mass of the second star is 3.5×10^30 kg, its velocity is < 1.0×10^4, -2.0×10^4, 9.0×10^4 > m/s, and this second star is located at < 1.04×10^12, -3.94×10^12, 3.96×10^12 > m relative to the center of the cluster of stars.
At t = 1.0×105 s, what is the approximate momentum of the first star? (in vector coordinates)
Was told to use Momentum principle, position update formula, and Newton's gravitational force law.
I keep on getting <3E35, 3.5E35, -3.5E35>kg m/s
The force of gravity I keep on calculating is not significant in that time to change the momentum of the particle.
Hi physics1311, welcome to Physics Forums.
You'll have to show your attempt at a solution (how did you arrive at the momentum vector that you found) before we help.
First I used Newtons gravitational force equation. Fg= GM1M2/r^2
M1=5E30 kg is given
M2 = 3.5E30 kg is given
G = 6.66E-11
Calculated R by using pythagorean theory for both coordinates and adding together
I got R =1.14E13
Then using the force calculated I used the momentum principle, delta p = Fnet delta t
M1=5E30 kg is given
G = 6.66E-11
I got R =1.14E13
That distance doesn't look right. What's the formula for the distance between two points?
That'll work for the Δp provided that Fnet remains fairly constant over the timestep Δt.
EDIT: Also, you'll need to express Fnet as a vector, since the resulting momentum will also be a vector quantity.
Okay, thanks for that tip. I used the distance formula sqrt((x2-x1)^2+(y2-y1)^2+(z2-z1)^2) equals distance.
I got r = 8.25E10m
I then plugged it into the equation for gravitational force. F= GM1M2/r^2
I got Fg=1.72E29
Then using this force I did p(final)-p(initial) = Fg delta(t) for each coordinate
My answer was <3.17E35, 3.67E35, -3.33E35>
and I tried making Fg negative which gave me <2.83E35, 3.33E35, -3.67E35>
neiter answers were right, what am I doing wrong?
How do you express Fnet as a vector?
I got r = 8.25E10m
I got Fg=1.72E29
You need to use vector equations to calculate your momentum. You've calculated the MAGNITUDE of the force that occurs between the two stars. Now you need to apply the other part of the vector property: the direction.
The gravitational force acts along a line connecting the centers of the two stars. You need to find a unit vector that lies on that line in the direction which the force is acting on the star in question (star #1 in this scenario). The force vector will then be the magnitude of the force multiplied by that unit vector.
How do you find a unit vector that lies along the line connecting two points?
