Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Drawing the lattice curves of a transformation (http://www.physicsforums.com/showthread.php?t=577353)
ElijahRockers Feb13-12 07:54 PM
Draw the lattice lines for the following transformation.
[itex]x=se^t[/itex]
[itex]y=se^-t[/itex]
3. The attempt at a solution
Trying to draw this transformation. So first thing I did was let t be constant. I then used substitution to show that [itex]x=ye^{2c}[/itex]. This is the set of all lines (as C is changed) with a positive slope that go through the origin, if I am not mistaken, which is the transform of the 'S' lattice of the grid.
For the next step I let S be constant, and used substitution to get what I think should be...
[itex]x=Ce^{-\frac{lny}{lnC}}[/itex], and this would be the transform of the 't' lattice, if I did that right.
What am I looking at here?
I used wolframalpha to graph several instances of this, with C = 1,2 and 3, and seemed to give me wildly different graphs each time. Did I do that right? It seems like C=1,2 are hyperbolas with their asymptotes along the x and y axes, but C = 3 gives me something I've never seen before. Sort of like a hyperbola, but one of the sides has been flipped into a different quadrant.
Any push in the right direction would be helpful, thanks.
EDIT: I just realized that C can't be 1 right? because ln C would be 0, and that would make the denominator 0 in the exponent part of the equation...? Also I tried to graph it with my TI-84, but it only gave me the portion of the graph in the first quadrant. Why is that?
EDIT: Also, my graphing calculator gets funky when I graph this equation for C=1/4
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
