Fourier transform of pulse sequence of varying pulse widths
The discussion focuses on the Fourier transform of a sequence of 16 pulses with varying duty cycles that repeat periodically. Key insights include the understanding that the periodicity of the pulse sequence determines the lowest frequency in the spectrum, while variations in pulse width affect the width of the lobes in the Fourier series. The interaction of frequency components leads to the generation of harmonics and sidebands, particularly when considering phase modulation. The Bessel functions play a crucial role in calculating the effects of modulation on the Fourier transform.
  • Understanding of Fourier transforms and frequency domain analysis
  • Knowledge of pulse sequences and duty cycles
  • Familiarity with Bessel functions and their application in modulation
  • Experience with oscilloscopes and FFT analysis
  • Study the Fourier transform of periodic pulse trains and their harmonic content
  • Explore the application of Bessel functions in phase modulation scenarios
  • Learn how to visualize Fourier transforms using oscilloscopes and FFT tools
  • Investigate the effects of varying duty cycles on frequency response in pulse sequences
Electrical engineers, signal processing specialists, and anyone involved in analyzing pulse sequences and their frequency components will benefit from this discussion.
jrive
I'm confused as to what to expect when I take, for example, the Fourier transform of a sequence of 16 pulses of varying duty cycles, repeating. That is, after the 16th pulse, the entire sequence repeats.
My confusion is in the interaction of the frequency components of each pulse within the sequence, and the fact that these repeat at some periodic rate (the sequence repeats).
I understand that a single pulse results in a sync function response in the frequency domain. And in a periodic pulse train, the period determines the separation between frequency bins, and the pulse width in the the width of the lobes in the Fourier series. What I don't get then is what happens when we have periodicity at the "group" level (every sequence), but not from one pulse to the next within a sequence (although the pulse width varies, but the period does not ---maybe that's the key).
thanks!
The periodicity of the 16 pulse sequence will determine the very lowest frequency in the spectrum, I believe. All other waveform artifacts will be expressed as harmonics. I'm not sure how applicable that is.
Apparently, if you consider the variation of the duty cycle as a phase modulation of some 50% duty cycle original signal you can calculate the effect on the Fourier transform. The effect is the addition of sidebands around the features of the unmodulated transform. According to some website i found, for modulation by a sinusoidal signal, the amplitudes of the sidebands follow the Bessel functions. And that's where I get scared and turn around and flee.
Yeah the Fourier transform of a the Heaviside rectangle function is the sync function, but the transform of a periodic square wave is not related to sync, it is just an infinite series of delta spikes starting at the fundamental frequency. I imagine that if you want to visualize it, you could start with a graph of the delta functions,begining at some point and then decaying in amplitude as the frequency coordinate increases, like a comb with teeth that get shorter from left to right... and then in your mind replace every "tooth" with a big blurry mess. Yeah that's how I see the spectrum of your periodic duty cycle function.
Can you just stick it into a oscilloscope and take a screen shot of the FFT?
  • · Replies 27 ·
