Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Precalculus Mathematics Homework (http://www.physicsforums.com/forumdisplay.php?f=155)
-   -   Word Problems with Parabolas (http://www.physicsforums.com/showthread.php?t=580395)
darshanpatel Feb22-12 08:13 PM
Roads are often designed with parabolic surfaces to allow rain to drain off. A particular road is that is 32 feet wide is .4 feet higher in in the center then on the sides.
a) Find an equation if the parabola that models the road surface. (Assume that the orgin is at the center of the road.)
b) How far from the center of the road is the road surface .1 feet lower then in the middle?
2. Relevant equations
-None-
3. The attempt at a solution
x^2=4py
x^2= 4(.4)y
x^2=1.6y
^part (a) Correct?
x^2=1.6(.3)
x^2=.48
x = .693 feet away from the center
^Part (b) -Correct?
I kind of have a basis but I am a little wary about the answers.
Dick Feb22-12 08:52 PM
Re: Word Problems with Parabolas
The form x^2=4py is fine. If the origin is the center of the road then a point at the center of the road is x=0, y=0 and x is the distance from the center of the road and y is the elevation of the road. What should y be if x is 16?
darshanpatel Feb22-12 08:54 PM
y=.4
but what next?
Dick Feb22-12 08:56 PM
Quote:
Quote by darshanpatel (Post 3779054)
y=.4
but what next?
Use that to solve for p. p isn't equal to 0.4.
darshanpatel Feb22-12 09:48 PM
so like x^2=4py
x^2=4p(.4)
(1/.4)x^2=4p
4p=1/.4
p=1/1.6
x^2=4(1/1.6)y
x^2=6.4y
is that right?
becuase the first time i thought that (0, .4) was the focus, and p=.4 from the focus...
Dick Feb22-12 10:00 PM
Quote:
Quote by darshanpatel (Post 3779135)
so like x^2=4py
x^2=4p(.4)
(1/.4)x^2=4p
4p=1/.4
p=1/1.6
x^2=4(1/1.6)y
x^2=6.4y
is that right?
(1/.4)x^2=4p. x=16. What's p? It's not 1.6 either.
darshanpatel Feb22-12 10:03 PM
p=160
so the equation for the graph would be x^2=640y?
and plugging in .3 for y
would get me answer to part (b)
13.856 feet from center?
Dick Feb22-12 10:08 PM
Quote:
Quote by darshanpatel (Post 3779162)
p=160
Yes for the first part. .4 is how far the road is below the center at x=16. The problem is asking "How far from the center of the road is the road surface .1 feet lower then in the middle?". I wouldn't plug in .3 for y.
darshanpatel Feb22-12 10:33 PM
oh, i was thinking of like where is the road only .3 feet or whatever,
do i plug .1 in?
Solved it for .1 and got 8
Dick Feb22-12 10:37 PM
Quote:
Quote by darshanpatel (Post 3779208)
do i plug .1 in?
I really don't like responses like "do i plug .1 in?". Do you or don't you? Sketch a picture of the road surface and tell me.
darshanpatel Feb22-12 10:41 PM
What do you mean you don't like them? I wasn't trying to be rude or anything.
You do plug in .1
Dick Feb22-12 10:48 PM
Quote:
Quote by darshanpatel (Post 3779221)
You do plug in .1
I didn't think you were trying to be rude or anything. I just like hearing "You do plug in .1" better than the "?" thing. Yes, you are right. And for the equation of the road surface they might like x^2=(-640)y better than x^2=640y. x^2=640y is sort of 'upside down'.
darshanpatel Feb23-12 05:27 PM
x^2=640y is upside down?
I don't understand.
Mark44 Feb23-12 05:33 PM
Quote:
Quote by darshanpatel (Post 3780771)
I don't understand.
It's upside down relative to the road surface. The parabola above opens up - you want a parabola that opens down, so that water will drain off the road. That's what Dick meant by "upside down."
darshanpatel Feb23-12 05:58 PM
ohhhhhhhhhhhhhhhhhhhhh, thank you, that makes a lot more sense, how would you show the work so that the number comes out to x^2=-640y?
Would you use -.4 when making the equation becuase it is 'upside down' now?
But would it matter because the answer comes out to the same thing no matter what?
Mark44 Feb23-12 06:53 PM
Quote:
Quote by darshanpatel (Post 3780821)
Start the work you did earlier with x2 = -4py (with p > 0) to get a parabola that opens down.
darshanpatel Feb23-12 08:10 PM
Can you help me with how the graph would look?
It's not for my homework, its just so I can understand it.
How would the parabola open and where?
Also to get part (b)
would you plug in -.1 for y and solve?
Becuase when I just plugged in .1 it would give me a negative answer
Mark44 Feb23-12 08:45 PM
Quote:
Quote by darshanpatel (Post 3781015)
How do you think the graph should look? You want the water to drain off the road, so it should have the high point at the center of the road's cross section.
This means you want a parabola that opens down. If the cross section of the road looked like a parabola that opened up, water would collect in the middle of the road, which isn't good.
Do as Dick suggested many posts ago by putting the vertex of the parabola at the origin. The left and right edges of the road will be at (-16, -.4) and (16, -.4).
If you substitute the x and y values of either point into x2 = -4py, you should be able to solve for p, which will be a positive number.
If the high point of the road is at (0, 0), every other point will have y values that are negative. You should get two x-values when y = -.1.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
