Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Electrical Engineering (http://www.physicsforums.com/forumdisplay.php?f=102)
-   -   Led shift setup question (http://www.physicsforums.com/showthread.php?t=580750)
chess0990 Feb23-12 05:48 PM
led shift setup question
hello I'm working on a manual shift override on an automatic transmission i have most of my design completed but have no clue where to begin the second half. the idea is to create something to tell me what gear i am in, i wanted to connect a circuit in parallel to the triggers for shifting to where clicking the up-shift trigger moves from one led to the next in the right direction and vise-verse for the downshift trigger, in all it would be 4 leds in total because it is a for gear transmission. could this be done without arduino? any ideas on how to do it?
any help is much appreciated so thank you very much in advanced
http://s12.postimage.org/doyvrzgj1/fin.png
cybhunter Feb24-12 10:27 PM
Re: led shift setup question
depending upon the type of drive (ie front/ rear) you may be able to compare the rotational speeds of the engine versus the rotational speed of the driveshaft (gear ratios). With that, a frequency to voltage converter with a comparator circuit to compare scalar values of the engine speed with the drive shaft might work
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
