Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Advanced Physics Homework (http://www.physicsforums.com/forumdisplay.php?f=154)
-   -   Beads on a hoop that cause elevation (http://www.physicsforums.com/showthread.php?t=580855)
michelle15g Feb24-12 03:12 AM
There are two beads at the top of a hoop that is tied by a string. The beads start moving downward on the hoop on each side. M is the hoop's mass and m represents each bead's mass.
What is that mass ratio that will cause the hoop to elevate.
2. Relevant equations
T>= (M +2m)g
3. The attempt at a solution
I tried to go about this question but I couldn't finish the equations.
I know that the momentum on the x axis isn't relevant since the beads cancel each other out.
I'm not sure how to use the hoop as a constraint. I can find the difference in potential energy but I can't seem to connect it to the force - only to the momentum.
I would really appreciate the help.
tiny-tim Feb24-12 04:42 AM
welcome to pf!
hi michelle! welcome to pf! :wink:
Quote:
Quote by michelle15g (Post 3781504)
assume the hoop is fixed, and use conservation of energy to find the bead-speed at a general angle θ
(i expect you've already done that :wink:)
then find the acceleration of the beads,
then the reaction force on the beads
what do you get? :smile:
michelle15g Feb24-12 05:57 AM
Re: Beads on a hoop that cause elevation
Thank you very much. My problem was that I kept skipping to the bottom instead of finding the speed at every angle in which case the integral was irrelevant.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
