Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Electrical Engineering (http://www.physicsforums.com/forumdisplay.php?f=102)
-   -   Generator hunting when parallel (http://www.physicsforums.com/showthread.php?t=581476)
faizmal Feb26-12 07:28 AM
Evening to all, I'm electrician onboard AHTS vessel. Currently I've have problem with generators onboard my vessel. For your info, we have 4 generators onboard. When paralleling with generator No. 1 and 2, the generator will be hunting if the load is low. But if running only generator 1 or 2, there are no problem. This happened also if we paralleling with 3 generators with generator no. 2. I suspected that there is a problem with generator No. 2. Hope I can get information regarding this matter. Thanks.
256bits Feb26-12 09:52 AM
Re: Generator hunting when parallel
What drives each generator?
jim hardy Feb26-12 11:46 AM
Check droop settings on governors?
Sounds like #2 is different trom 1 & 3 somehow.
Could be as simple as excess play or friction in mechanical throttle linkage...
Jobrag Feb27-12 07:17 AM
What type of governors do you have mechanical or electronic?
What size are your generators?
Do you have a large load that you can switch on and off easily?
When running single generators does the frequency remain stable?
psparky Feb27-12 10:10 AM
What does "hunting" mean in this application? Surging or something like that?
Jobrag Feb29-12 05:44 AM
It means that the load is constantly shifted from one generator to another and the back again.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
