Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Programming & Computer Science (http://www.physicsforums.com/forumdisplay.php?f=165)
-   -   Error: expected constructor, destructor, or type conversion before ';' token (http://www.physicsforums.com/showthread.php?t=583891)
creativen Mar4-12 09:42 PM
error: expected constructor, destructor, or type conversion before ';' token
I'm newbie in C programming...
i'm trying to make my arduino board works but still find error when compiling the C programming, the errors are:
driving7segmentusingmultipleshiftregisters3:2: error: expected constructor, destructor, or type conversion before ';' token
driving7segmentusingmultipleshiftregisters3:85: error: ISO C++ forbids declaration of 'sendSerialDatainitial' with no type
driving7segmentusingmultipleshiftregisters3.cpp: In function 'int sendSerialDatainitial()':
driving7segmentusingmultipleshiftregisters3:95: error: assignment of read-only variable 'g_pinCommLatch1'
driving7segmentusingmultipleshiftregisters3:96: error: expected `;' before 'g_pinCommLatch2'
driving7segmentusingmultipleshiftregisters3:99: error: expected `;' before ')' token
driving7segmentusingmultipleshiftregisters:127: error: expected `}' at end of input
Code:
sendSerialDataInitial (void);
void setup();
int switchPin1 = A0;
int switchPin2 = A2;
int switchPin3 = A4;
int resetPin1  = A1;
int resetPin2  = A3;
int resetPin3  = A5;
int no1=1;
int no2=1;
int no3=1;
// This pin gets sets low when I want the 595s to listen
const int  g_pinCommLatch1 = 5;
const int  g_pinCommLatch2 = 6;
const int  g_pinCommLatch3 = 7;
// This pin is used to pass the next bit
const int  g_pinData1    = 8;
const int  g_pinData2    = 9;
const int  g_pinData3    = 10;
// This pin is used by ShiftOut to toggle to say there's another bit to shift
const int  g_pinClock1    = 11;
const int  g_pinClock2    = 12;
const int  g_pinClock3    = 13;
// Definitions of the 7-bit values for displaying digits
byte g_digits [10];
// Current number being displayed
int g_numberToDisplay1 = 0;
int g_numberToDisplay2 = 0;
int g_numberToDisplay3 = 0;
// Number of shift registers in use
const int g_registers = 5;
// Array of numbers to pass to shift registers
byte g_registerArray [g_registers];
byte *pValueArray1;
byte *pValueArray2;
byte *pValueArray3;
byte reg1;
byte reg2;
byte reg3;
byte value1;
byte value2;
byte value3;
byte bitMask1;
byte bitMask2;
byte bitMask3;
void setup()
  pinMode (g_pinCommLatch1, OUTPUT);
  pinMode (g_pinCommLatch2, OUTPUT);
  pinMode (g_pinCommLatch3, OUTPUT);
  pinMode (g_pinClock1, OUTPUT);
  pinMode (g_pinClock2, OUTPUT);
  pinMode (g_pinClock3, OUTPUT);
  pinMode (g_pinData1, OUTPUT);
  pinMode (g_pinData2, OUTPUT);
  pinMode (g_pinData3, OUTPUT);
  // Setup the digits array
  g_digits [0] = 1 + 2 + 4 + 8 + 16 + 32 + 00;
  g_digits [1] = 0 + 2 + 4 + 0 + 00 + 00 + 00;
  g_digits [2] = 1 + 2 + 0 + 8 + 16 + 00 + 64;
  g_digits [3] = 1 + 2 + 4 + 8 + 00 + 00 + 64;
  g_digits [4] = 0 + 2 + 4 + 0 + 00 + 32 + 64;
  g_digits [5] = 1 + 0 + 4 + 8 + 00 + 32 + 64;
  g_digits [6] = 1 + 0 + 4 + 8 + 16 + 32 + 64;
  g_digits [7] = 1 + 2 + 4 + 0 + 00 + 00 + 00;
  g_digits [8] = 1 + 2 + 4 + 8 + 16 + 32 + 64;
  g_digits [9] = 1 + 2 + 4 + 8 + 00 + 32 + 64;
sendSerialDatainitial(void)
  {  g_registerArray [4] = g_digits [0];
    g_registerArray [3] = g_digits [0];
    g_registerArray [2] = g_digits [0];
    g_registerArray [1] = g_digits [0];
    g_registerArray [0] = g_digits [0];
  // Signal to the 595s to listen for data
  digitalWrite (g_pinCommLatch1,LOW);
  g_pinCommLatch1=LOW
  g_pinCommLatch2=LOW
  g_pinCommLatch3=LOW
  for (reg1 = registerCount1; reg1 > 0; reg1--)
    byte value1 = pValueArray1 [reg1-1];
    for (byte bitMask1 = 128; bitMask1 > 0; bitMask1 >>= 1)
      digitalWrite (g_pinClock1, LOW);
      digitalWrite (g_pinData1, value1 & bitMask1 ? HIGH : LOW);
      digitalWrite (g_pinClock1, HIGH);
  for (byte reg2 = registerCount2; reg2 > 0; reg2--)
    byte value2 = pValueArray2 [reg2-1];
    for (byte bitMask2 = 128; bitMask2 > 0; bitMask2 >>= 1)
      digitalWrite (g_pinClock2, LOW);
      digitalWrite (g_pinData2, value2 & bitMask2 ? HIGH : LOW);
      digitalWrite (g_pinClock2, HIGH);
  for (byte reg3 = registerCount3; reg3 > 0; reg3--)
    byte value3 = pValueArray3 [reg3-1];
    for (byte bitMask3 = 128; bitMask3 > 0; bitMask3 >>= 1)
      digitalWrite (g_pinClock3, LOW);
      digitalWrite (g_pinData3, value3 & bitMask3 ? HIGH : LOW);
      digitalWrite (g_pinClock3, HIGH);
  // Signal to the 595s that I'm done sending
  digitalWrite (g_pinCommLatch1, HIGH);
  digitalWrite (g_pinCommLatch2, HIGH);
  digitalWrite (g_pinCommLatch3, HIGH);
Tombol:
  GoSub Blinks
  if switchPin1=1 and a=1 then
  GoSub Counter1
  a=0
  elseif switchPin1=0 and a=0 then
  a=1
  end if
  if switchPin2=1 and b=1 then
  GoSub Counter2
  b=0
  elseif switchPin2=0 and b=0 then
  b=1
  end if
  if switchPin3=1 and c=1 then
  GoSub Counter3
  c=0
  elseif switchPin3=0 and c=0 then
  c=1
  end if
  if resetPin1=1 and a=1 then
  GoSub reset1
  end if
  if resetPin2=1 and a=1 then
  GoSub reset2
  end if
  if resetPin3=1 and a=1 then
  GoSub reset3
  end if
GoSub Show1
GoSub Show2
GoSub Show3
GoSub SendSerialData1
GoSub SendSerialData2
GoSub SendSerialData3
delay(1000
GoSub Tombol
Blinks:
  int a = random (1,3);
  int b = random (1,4);
  int c = random (1,5);
  if (a==3)
    digitalWrite(2, HIGH);  // set the LED on
    end if
  if (b==3)
    digitalWrite(3, HIGH);  // set the LED on
    end if
  if (c==3)
    end if
  return
Counter1:
  g_numberToDisplay1 = no1;
  no1=no1+1;
  return
Counter2:
  g_numberToDisplay2 = no2;
  no2=no2+1;
  return
Counter3:
  g_numberToDisplay3 = no3;
  no3=no3+1;
  return
Reset1:
  gnumberToDisplay1 = no1;
  no1=0
  return
Reset2:
  gnumberToDisplay2 = no2;
  no2=0
  return
Reset3:
  gnumberToDisplay3 = no3;
  no3=0
  return
show1:
  if (g_numberToDisplay1 < 10)
    g_registerArray [0] = g_digits [g_numberToDisplay1];
  else if (g_numberToDisplay1 < 100)
    g_registerArray [1] = g_digits [g_numberToDisplay1 / 10];
    g_registerArray [0] = g_digits [g_numberToDisplay1 % 10];
  else if (g_numberToDisplay1 < 1000)
    g_registerArray [2] = g_digits [g_numberToDisplay1 / 100];
    g_registerArray [1] = g_digits [(g_numberToDisplay1 % 100) / 10];
  else if (g_numberToDisplay1 < 10000)
    g_registerArray [3] = g_digits [g_numberToDisplay1 / 1000];
    g_registerArray [2] = g_digits [(g_numberToDisplay1 % 1000) / 100];
  else
    g_registerArray [4] = g_digits [g_numberToDisplay1 / 10000];
    g_registerArray [3] = g_digits [(g_numberToDisplay1 % 10000) / 1000];
  return
show2:
  if (g_numberToDisplay2 < 10)
    g_registerArray [0] = g_digits [g_numberToDisplay2];
  else if (g_numberToDisplay2 < 100)
    g_registerArray [1] = g_digits [g_numberToDisplay2 / 10];
    g_registerArray [0] = g_digits [g_numberToDisplay2 % 10];
  else if (g_numberToDisplay2 < 1000)
    g_registerArray [2] = g_digits [g_numberToDisplay2 / 100];
    g_registerArray [1] = g_digits [(g_numberToDisplay2 % 100) / 10];
  else if (g_numberToDisplay2 < 10000)
    g_registerArray [3] = g_digits [g_numberToDisplay2 / 1000];
    g_registerArray [2] = g_digits [(g_numberToDisplay2 % 1000) / 100];
  else
    g_registerArray [4] = g_digits [g_numberToDisplay2 / 10000];
    g_registerArray [3] = g_digits [(g_numberToDisplay2 % 10000) / 1000];
  return
show3:
  if (g_numberToDisplay3 < 10)
    g_registerArray [0] = g_digits [g_numberToDisplay3];
  else if (g_numberToDisplay3 < 100)
    g_registerArray [1] = g_digits [g_numberToDisplay3 / 10];
    g_registerArray [0] = g_digits [g_numberToDisplay3 % 10];
  else if (g_numberToDisplay3 < 1000)
    g_registerArray [2] = g_digits [g_numberToDisplay3 / 100];
    g_registerArray [1] = g_digits [(g_numberToDisplay3 % 100) / 10];
  else if (g_numberToDisplay3 < 10000)
    g_registerArray [3] = g_digits [g_numberToDisplay3 / 1000];
    g_registerArray [2] = g_digits [(g_numberToDisplay3 % 1000) / 100];
  else
    g_registerArray [4] = g_digits [g_numberToDisplay3 / 10000];
    g_registerArray [3] = g_digits [(g_numberToDisplay3 % 10000) / 1000];
  return
sendSerialData1:
  digitalWrite (g_pinCommLatch1, LOW);
  for (byte reg1 = registerCount1; reg1 > 0; reg1--)
    byte value1 = pValueArray1 [reg1 - 1];
return
sendSerialData2:
  digitalWrite (g_pinCommLatch2, LOW);
    byte value2 = pValueArray2 [reg2 - 1];
return
sendSerialData3:
  digitalWrite (g_pinCommLatch3, LOW);
    byte value3 = pValueArray3 [reg3 - 1];
return
phylotree Mar5-12 12:20 AM
Re: error: expected constructor, destructor, or type conversion before ';' token
1. Function declaration needs a return type (C/C++ is a static typed language).
2. const declaration means the object's properties are not changeable until the const-ness is not cast away.
creativen Mar5-12 12:24 AM
Do you have any idea how to make return value in void declaration?
coz actually I found my program using Basic and using C compiler...
Actually I want to return the value....
phylotree Mar5-12 12:37 AM
There are many ways to achieve that, you can simply define your objects globally (assuming they are still in the same accessible scope)
Code:
int x;
void func(int y)
    x=y;
    return; //unnecessary
int func(int y)
    x=y;
    return  someIntValue; //this might be used as an exit code for someone who wants to check
int getX()
  return x; // this is the second function's y value
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
