Why doesn't energy have direction?
  • Context: Undergrad
  • Thread starter Thread starter Vincentius
    Direction Energy
The discussion centers around the concept of energy and whether it possesses direction. Participants explore various forms of energy, such as kinetic and potential energy, and their relationship to directionality, particularly in the context of physics principles like conservation of energy and the nature of forces.
  • Some participants argue that energy is fundamentally a scalar quantity and does not have direction, while others suggest that certain forms of energy can be associated with directional concepts, particularly in specific contexts.
  • One participant notes that kinetic energy can be linked to the direction of velocity, while potential energy may have directional associations in certain scenarios, such as gravitational fields.
  • Another viewpoint emphasizes that if energy had a direction, it would complicate the conservation of energy, particularly in systems like circular orbits or simple harmonic motion.
  • Some participants introduce the idea that in the framework of relativity, energy can be viewed as part of a momentum 4-vector, which includes a time component, suggesting a directional aspect in a 4-dimensional space-time context.
  • There are discussions about the implications of Noether's theorem regarding conservation laws and the relationship between energy and momentum.
  • Several participants express confusion about the relationship between energy, force, and direction, with some asserting that while energy itself is scalar, the gradient of potential energy can imply direction.
Participants do not reach a consensus on whether energy can be considered to have direction. Multiple competing views are presented, with some emphasizing the scalar nature of energy and others proposing that certain contexts allow for directional interpretations.
Some discussions reference the complexities of energy in relativistic contexts and the implications of conservation laws, but these points remain unresolved and depend on the definitions and frameworks used by participants.
Vincentius
Hi, I try to understand why energy can not have a direction. For instance, kinetic energy of a particle could be considered to have the direction of its velocity. Potential energy of a body in a gravitational field also can be considered to have direction (at least in the two-body case). The same for a mass and a spring. Of course, there are cases where forces balance and the potential energy has no associated direction anymore (as with a central body that is being pulled by two springs in opposite directions), still the separate components of potential energy of the central body can be associated with a direction and so can the potential energies of the two bodies at the other sites of the springs. I realize there are some complications and questions, but conceptually I do not see why energy does not have direction.
Any references on this subject?
Thanks!
It's just not defined that way...but as a scalar, a non directional entity.
Energy is the ability to do work. Work is defined as a force acting over a distance: W = Fd.
more precisely: W = F[cos] d, a scalar, a dot product, and the work can be either positive or negative. For example when you lower an object to the floor, the work done on the object by the upward force of a hand is negative...you are opposing the 'force' of gravity...and a 'direction' or such energies may not be obvious in the general situation.
For things like particle motion, or throwing a ball, giving a direction to 'energy' does have some intutitive appeal. But many forms of energy like thermal energy, radioactivity,zero point energy, chemistry, etc. don't have an easily defined direction. Some 'work' in many directions simultaneously.
Also energy a scalar energy has some attributes not so readily apparent:
In classical physics energy is considered a scalar quantity, the canonical conjugate to time. In special relativity energy is also a scalar (although not a Lorentz scalar but a time component of the energy-momentum 4-vector).[14] In other words, energy is invariant with respect to rotations of space, but not invariant with respect to rotations of space-time (= boosts).
http://en.wikipedia.org/wiki/Energy
If energy had a direction then it would not be conserved. Think about a circular orbit, you would have a continually changing KE with no change in PE. Or simple harmonic motion, each time it passes through equilibrium there is no PE and the KE is reversed.
In a sense, energy does have a direction. In the 4-dimensional geometry of space-time, energy is the time component of the momentum vector. Thus, the momentum 4-vector of a particle is p=(E/c, px,py,pz), analogous to its position 4-vector (t/c,x,y,z). So energy points in the time direction. When we do a Lorentz transformation, energy and momentum mix in the same way that space and time mix.
For ordinary situations, where the velocities involved are much less than the speed of light, the velocity in the time direction is very much greater than any of the spatial velocities. In this case, the energy can be treated essentially as a scalar.
phyzguy:
Does your description hold inside the Schwarzschild radius of a black hole? ...where 'time becomes an inward radial direction' ??
Your post seems inconsistent with Dalespams...but I am not sure I understand the consequences of his post...
When posting above, I was wondering myself about the consequences of the OP question regarding conservation of energy...and implications wrsp Noether's Theorem. If anyone can comment regarding those implications I'd appreciate it.
Did you forget Energy-Momentum Tensor and Energy flux? in electromagnetic field description there is kind of different rates of energy flaw in different directions, and this can be thought as a kind of "energy direction", anyway this flaw should be transformed in a tricky way (i.e Lorentz transformations) that will keep the "total flux" conserved.
His post is inconsistent with mine, but his is correct. I was giving a non-relativistic answer, his was relativistic. I assumed that the OP was specifically referring to a spatial direction, not time.
Naty1 said:
phyzguy:
Conservation of energy is a consequence of Noether's theorem and the Lagrangian being invariant with respect to time translation.
Dalespam:
I thought the first sentence might be the case as I was initially posting...but I can't figure out how your remaining statements follow. Oh, good grief!... :approve:
The lightbulb finally lit...I've been misreading your post: You are assuming a direction and properly noting as a consequence that therefore the KE [direction] would be continually changing. DUH!
I am definitely getting too old for this stuff...
I shall now return to installing a new vanity countertop for my wife. THAT I can handle.
Exactly. Sorry about the lack of clarity. It was a rather brief post.
If you derive the definition of energy from the work done by a force its value will only be meaningful if the force is in the same direction of the displacement. Thus if you equate energy with ability to perform work it would be unecessary to specify a direction since the force will always be parallel to the dispacement it causes.
Hello all .
Suppose we have a source of energy ( like potential energy ) that can cause moving an object .
My questions are :
1 - Is this source a pure potential energy or a momentum-energy ?
Because if we want to move a object we must give it momentum . or i am wrong ? we must give it energy ?
2 - If energy has no direction how can get direction to object ?
Doesn't a force contain energy but with force you have given a vector to that energy?
It's quite hard to understand what is meant by some of these questions.
Energy is a scalar, whether it's potential energy or kinetic. Force is a vector. One does not contain the other.
big_bounce said:
Hello all .
My questions are :
Both momentum and energy are conserved.
Energy has no direction, but the gradient of a potential does.
And one doesn't cause the other.
I am a new collegian and didn't read any about gradient .
So let's talk about particles .
Suppose there are two single electron , one of them is in motion and another is at rest .
Electron in motion possesses kinetic energy and momentum and when it collide with electron at rest cause electron at rest start to motion in certain direction . Since energy doesn't have direction so this direction comes from momentum ( momentum is vector ) . am i right ?
Now suppose we have an electron at rest and a source of energy ( like potential energy ) .
My questions are :
Potential energy can "directly" cause to motion the electron ? or it must change form to such as electromagnetism radiation and then cause to motion it ?
Does the momentum for motion this electron come from potential energy ?
If yes , is the source of energy really "pure energy" ? or include another quantity like momentum ?
And in last , for motion which is more fundamental ? energy or momentum ?
May be you'll say force but this force comes from what ? momentum or energy ?
Thanks for your answer .
My questions are :
Anyone can answer these questions ?
Yes.
My questions are :
I am not sure that this question makes sense. An electromagnetic potential is just a different way to represent an electromagnetic field. They are two different descriptions of the same phenomena. There is no sensible way that I can think of to change a potential into a field, they are always both present.
No.
Neither. They are on equal footing. Conservation of energy comes from time invariance of the Lagrangian and conservation of momentum comes from spatial invariance of the Lagrangian.
Are you sure? [itex]F= -\frac{dU}{dx}[/itex] if I remember correctly.
Thank you .
Another question :
If i want moving an object at rest from point A to B , i need energy ?
Does the object during this displacement need momentum ?Suppose an object is attached to a spring tip .
If i want moving this object from normal position ( point A ) to point B , i need energy . am i right ?
Do i need momentum for this displacement , too ?
That's a quantitative relation. It says nothing about causation.
Ah, perhaps I misunderstood your original quote. What I meant was that a change in one results in a change in the other, assuming that there are no outside forces(so they are not independent of each other).
big_bounce said:
Thank you .
Another question :
Yes to both questions. In order to move it, it must have some velocity. The velocity determines both the energy and momentum. These can be made as small as you like by moving it slowly enough.
When we do work , we always moving an object from one point to another point .
So can we say for do work we always need momentum , too ?
Yes, although the work can be made arbitrarily large while the momentum is made arbitrarily small.
Is there any equation for calculate momentum when we do work ?
Can we calculate momentum with having Force and Distance in W=f.d or need another parameters (Variables) ?
You do need other parameters. Also, it depends on the scenario. Suppose that the work is being done pushing a block at a constant speed against friction. Then f and d provide no information about momentum at all, so you still need both m and v in addition to f and d.
  • · Replies 54 ·
  • · Replies 39 ·
  • · Replies 24 ·
