Interference terms in particle spin
The discussion centers on the role of interference terms in the behavior of particles, specifically electrons, in the double slit experiment and the Stern-Gerlach experiment. It is established that interference terms do not influence the deflection of electrons in the Stern-Gerlach experiment; rather, the deflection is a direct result of the interaction between the electron's spin and the external magnetic field. The density matrix for an electron with spin |+X> contains off-diagonal terms indicating interference, but these do not dictate the outcome of the spin measurement.
  • Understanding of quantum mechanics concepts, particularly spin and measurement.
  • Familiarity with the double slit experiment and its implications for wave-particle duality.
  • Knowledge of the Stern-Gerlach experiment and its significance in demonstrating spin states.
  • Basic grasp of density matrices and their role in quantum state representation.
  • Study the implications of the double slit experiment on quantum mechanics and wave-particle duality.
  • Research the mathematical formulation of the Stern-Gerlach experiment and its outcomes.
  • Explore the concept of density matrices in quantum mechanics, focusing on off-diagonal terms.
  • Investigate the interaction between magnetic fields and electron spins in various experimental setups.
Physicists, quantum mechanics students, and researchers interested in the foundational principles of quantum behavior and measurement techniques.
deneve
In the double slit experiment there are interference terms which are responsible for the way in which particles appear on a screen (diffraction pattern). The density matrix for an electron with spin |+X> going into a stern Gerlach alligned in the z direction also has off diagonal terms which idicate interference.
Is it correct to think that these interference terms are responsible for the fact that some electrons end up going up and others down just as particles go above and below a datum line which extends from the middle of the double slits to the screen?
Many thanks for any replies.
No, the interference terms are not responsible for the way in which electrons end up going up or down in the Stern-Gerlach experiment. In the Stern-Gerlach experiment, the spin of the electron interacts with a magnetic field, causing it to be deflected either up or down, depending on its spin. This is a result of the interaction between the electron's magnetic moment and the external magnetic field, and is not related to interference.
  • · Replies 28 ·
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 36 ·
10K
