Calculating Friction and Tension in a Pulley System
  • Thread starter Thread starter wow22
    Dynamics Friction
The discussion revolves around a physics problem involving a pulley system with two boxes of different masses connected by a rope. The first box is being pulled with a force at an angle, and the participants are tasked with calculating the frictional force and the tension in the connecting rope. Additionally, there is a second part concerning a rope hanging off a table and its frictional properties.
  • Mixed
  • Participants discuss identifying forces and drawing free-body diagrams as a starting point for solving the problem. There is an attempt to equate forces and derive equations for friction and tension. Some express uncertainty about the information provided and the assumptions made, particularly regarding initial conditions and the setup of the second problem.
The discussion is ongoing, with participants exploring various interpretations of the problem statement. Some have made attempts to calculate acceleration and friction but express confusion about the setup and the information given. There is no explicit consensus on how to proceed, and some participants question the completeness of the problem as presented.
Participants note that the problem may lack sufficient information, such as initial velocities and acceleration details, which complicates the analysis. There is also mention of assumptions made regarding the initial state of the boxes.
wow22
1. a box has a mass of 100kg, and the second has a mass of 55kg. there is a rope between them that attaches them. there's a rope connecting to the first box, that is pulled with a force of 200N at 50 degrees above the horizontal. the box os moved 305cm for 5s
a) what is the frictional force on the boxes
b) what is the tension in the rope joining the two boxes
2.
a rope is hanging off the side of the table. the rope is 2m long. the coefficient of friction between the table and the rope is 0.62
what is the maximum length of the rope that can hang over without slipping?
1. i tried using d=vy1*t+0.5g*t^2 to find a. if i assumed vy1 is 0 because it starts from rest. then tried using Ef=Fappy-Ffs to find the mui in FFs...
2. Have no idea how to start
have no idea o-o'' what to do ><"
As you've written it, the first problem can't be solved because there isn't enough information. Please tell us the problem statement is exactly as it was given to you.
With force problems, the first thing you should do is identify all the forces acting and draw a free-body diagram for each object.
that's actually all the information given :s
that's why I'm findin it hard to do. but i found out how to do a).
to find friction:
equate the two equations
mass A: Ef=Fapp-FT --> Ft= Fapp-Ef
mass B: Ef= Ft-Ffs --> Ft= Ffs + Ef
therefore:
Ffs+Ef = Fapp-Ef
Ffs= Fapp-Ef-Ef(second one)
acceleration found with d=v1y*t + 0.5g*t^2 = 0.24m/s^2
...but idk how to do b) :s
& I'm finding it hard to imagine the rope as a free body diagram.. cause half of its on the table and the other half is off.
so like half of it is lieing horizontally and the other half it lieing vertically.. i can't imagine what force is acting on what part... :s
I think in relaying the question here, you've changed the wording and ended up inadvertently omitting some necessary info. That's why I asked you to tell us what the problem statement is exactly as written. Your solution doesn't make sense to me, and as you've written the problem, it can't be solved without making arbitrary assumptions.
kkk...
a person pulls a string of two boxes across level ground. the first box has a mass of 100kg and the second, 55kg. pulling the rope attached to the first box with a force of 200N at 50 degrees above the horizontal. the box os moved 305cm for 5s
a) what is the frictional force acting on the boxes
thats it^ the entire question.
You can't solve that problem. You don't know the initial velocity, if the boxes accelerate, etc.
that's why we assumed that the inital velocity starts from rest, and found the acceleration to be 0.24m/s
it might not be right, but that's what most of us had done.
  • · Replies 38 ·
  • · Replies 18 ·
