Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Chemistry (http://www.physicsforums.com/forumdisplay.php?f=83)
-   -   The single most interesting chemistry journal article I've read in 5 years (http://www.physicsforums.com/showthread.php?t=587542)
gravenewworld Mar16-12 08:55 AM
Traceless protein labeling
http://www.nature.com/nchembio/journ...embio.157.html
http://www.nature.com/nchembio/journ...o0509-275.html
If this procedure really does work as they say, what a really, really slick idea this group has come up with. Not only does this have the potential to surpass GFP tagging for proteins, you can tune your affinity tags for almost any protein possible so long as you have a ligand for it (without having to do any genetic manipulation). Better yet, you can pick any single probe you wanted to, attach biotin, or almost anything else you could think of. It seems like a fantastic idea.
So can someone explain to me why this works? Why don't these traceless affinity tags simply attach to any old nucleophile within the cell? Why must the ligand direct it to the binding pocket of the targeted protein first before it will cleave? Does the hindrance of water prevent it from cleaving until it sees the binding pocket in order to undergo the Sn2 rxn with the nucleophilic protein amino acid residue (binding pocket shields the tosyl from water?)? The western blots they do look absolutely amazing, especially the one from the rat. The "proximity effects" mentioned seemed like a bunch of hand waving for explaining why it works and doesn't randomly attach any nucleophile, but hey if it works, it works.
Ygggdrasil Mar17-12 02:16 PM
Re: The single most interesting chemistry journal article I've read in 5 years
One important factor influencing the rate of chemical reactions is the concentration of reactants. The higher the concentration of reactants, the more frequently the reactants bump into each other giving them the opportunity to react. One way to speed up a chemical reaction (other than increasing the concentration of reactants) is to tether the reactants in order to increase their effective concentration (for example, see David Liu's work on DNA-directed synthesis, which uses DNA base pairing to bring small molecules together for chemical reactions). In the case of the tosyl chemistry described by Tsukiji et al., tethering the reactive group to the protein will greatly increase the frequency with which the reactive group collides with amino acids on the target protein surface, which in turn greatly increases the reaction rate. This is the "proximity effect" to which the authors refer.
The key to the paper seems to be that the tosyl reagents the authors produce are very poorly reactive. They report labeling yields of 75% when they react 40ÁM of target protein with 80ÁM reagent for 48 hours. In comparison, typical protein labeling reagents (such as N-hydroxysuccinimide or maleimide reagents) will give >90% labeling yields in a few hours. Thus, the reagent seems to be so poorly reactive that it will not react unless its reactant is present at very high concentrations (achieved here through tethering).
Now, the reagent is not 100% specific. If you look closely at the fluorescence image in figure 2b, you can see faint signal from the other proteins in lanes 1 and 2. So, the reagent is capable of reacting with any nucleophilic amino acid residue. However, these reactions occur very slowly unless the reagent gets tethered to a protein, in which case the reaction will occur at a much more rapid rate (although the labeling rate is still very slow compared to typical labeling reactions).
The slow rate of reaction is likely to limit the applicability of this technology and why I would not bet on this technology replacing GFP. Whereas GFP fluorescence matures in the tens of minutes, the tosyl chemistry seems to require a day or more of incubation with the ligand to achieve quantitative labeling. This can be problematic as may proteins turnover on a much faster timescale.
To combine this with some thoughts from another one of your posts, perhaps the ligand-dependent tethering idea could be used to speed the rate with which click chemistry reagents react with their targets.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
