Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Calculus & Beyond Homework (http://www.physicsforums.com/forumdisplay.php?f=156)
-   -   Linear Algebra - Matrix with given eigenvalues (http://www.physicsforums.com/showthread.php?t=593257)
roto25 Apr3-12 11:15 PM
Come up with a 2 x 2 matrix with 2 and 1 as the eigenvalues. All the entries must be positive.
Then, find a 3 x 3 matrix with 1, 2, 3 as eigenvalues.
3. The attempt at a solution
I found the characteristic equation for the 2x2 would be λ2 - 3λ + 2 = 0. But then I couldn't get a matrix with positive entries to work for that.
Dick Apr3-12 11:24 PM
Re: Linear Algebra - Matrix with given eigenvalues
Pick a diagonal matrix.
roto25 Apr3-12 11:28 PM
Does that count for the entries being positive though?
Dick Apr3-12 11:38 PM
Quote:
Quote by roto25 (Post 3849064)
Not really, no. Sorry. Better give this more thought than I gave this response.
roto25 Apr3-12 11:39 PM
thanks though!
micromass Apr4-12 06:12 AM
The 2x2-case is not so difficult. Remember (or prove) that the characteristic polynomail of a 2x2-matrix A is
[tex]\lambda^2-tr(A)\lambda+det(A)[/tex]
By the way, I think your characteristic polynomial is wrong.
HallsofIvy Apr4-12 06:17 AM
??? Why do the diagonal matrices
[tex]\begin{bmatrix}1 & 0 \\ 0 & 2\end{bmatrix}[/tex]
and
[tex]\begin{bmatrix} 1 & 0 & 0 \\ 0 & 2 & 0 \\ 0 & 0 & 3\end{bmatrix}[/tex]
NOT count as "all entries postive"?
micromass Apr4-12 06:18 AM
He probably doesn't consider 0 to be positive.
HallsofIvy Apr4-12 06:22 AM
But it is much easier to claim that 0 is positive!:tongue:
Thanks.
roto25 Apr4-12 07:42 AM
Oh, I had typed 3 instead of 2 for the characteristic polynomial. I ended up looking at this from a Hermitian matrix point of view.
And then I got the matrix:
0 i +1
i-1 3
And I did get the right eigenvalues from that. Does that work?
micromass Apr4-12 08:09 AM
You still have 0 as an entry, you don't want that.
roto25 Apr4-12 09:06 AM
Yeah, I didn't realize that at first. :/
Dick Apr4-12 09:08 AM
Quote:
Quote by roto25 (Post 3849508)
0 i +1
i-1 3
I don't think i+1 would be considered a positive number either. Stick to real entries. Your diagonal entries need to sum to 3, and their product should be greater than 2. Do you see why?
roto25 Apr4-12 10:06 AM
Yes. Theoretically, I know what it should do. I just can't actually find the right values to do it.
Dick Apr4-12 10:09 AM
Quote:
Quote by roto25 (Post 3849655)
Call one diagonal entry x. Then the other one must be 3-x. Can you find a positive value of x that makes x*(3-x)>2? Graph it.
roto25 Apr4-12 10:18 AM
Well, any value of x between 1 and 2 (like 1.1) work.
Dick Apr4-12 10:37 AM
Quote:
Quote by roto25 (Post 3849670)
Ok, so you just need to fill in the rest of the matrix.
roto25 Apr4-12 10:43 AM
but if I set x to be 1.1, my matrix would be
1.1 __
__ 1.9
And those two spaces have to be equivalent to 1.1*1.9 - 2, right?
because no matter what values I try, when the eigenvalues are getting closer to 1 and two, the matrix is just getting closer to the matrix of:
1 0
0 2
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
