J.J. Thomson's Experiment, Help
  • Thread starter Thread starter SuicideSteve
    Experiment
J.J. Thomson's experiment involves determining the mass-to-charge ratio (m/e) of an electron using electric and magnetic fields. The equations governing the motion of electrons are m(d²x/dt²) + He(dy/dt) = 0 and m(d²y/dt²) - He(dx/dt) = 0. The resulting path of the electrons is a cycloid, represented by the parametric equations x = {Em/H²e}(1 - cos([He/m]t)) and y = {Em/H²e}([He/m]t - sin([He/m]t)). The discussion highlights the importance of correctly substituting constants to derive the final equations.
  • Understanding of differential equations and their solutions
  • Familiarity with cycloid motion and parametric equations
  • Knowledge of electric and magnetic field interactions
  • Basic calculus, particularly differentiation and integration
  • Study the derivation of cycloid equations in classical mechanics
  • Explore the application of differential equations in physics
  • Learn about the significance of the mass-to-charge ratio in particle physics
  • Investigate the role of electric and magnetic fields in charged particle motion
Physics students, educators, and researchers interested in classical mechanics, electromagnetism, and the historical context of electron discovery will benefit from this discussion.
SuicideSteve
Okay, here is the problem I was given.
In Thomson's experimental determination of the ratio m/e of the mass to the charge of an electron, in which the electrons were subjected to an electric field of intensity E and a magnetic field of intensity H, the equations
m(d2x/dt2) + He(dy/dt) , m(d2y/dt2) - He(dx/dt) = 0 ,
were employed. If x=y=dx/dt=dy/dt=0 for t=0, show that the path is a cycloid whose parametric equations are:
x = {Em/H2e}(1 - cos([He/m]t))
y = {Em/H2e}([He/m]t - sin([He/m]t))
I have solved the differential equation by substituting 1 for the constants and come out with:
x = 1 - cost
y = t - sint
My problem is I can not figure out how to end up with the constants in the results.
Any help is greatly appreciated,
Thanks.
Steve.
I'm sorry, I believe I have posted this in the wrong section, as I am asking for help.
Why did you "substitute 1 for the constants"? It doesn't really simplify anything.
Differentiating the first equation one more time,
[tex]m(d^3x/dt^3) + He(d^2y/dt^2) = 0[/tex]
and we can substitute He dx/dt for [itex]d^2y/dt^2[/itex]
so we have
[tex]m(d^3x/dt^3)+ H^2e^2dx/dt= 0[/tex]
That has characteristic equation [itex]mr^3+ H^2e^2r= r(mr^2+ H^2e^2)= 0[/itex] which has roots 0, (He/m)i and -(He/m)i so that the general solution is
[tex]x(t)= C+ Dcos((He/m)t)+ E sin((He/m)t)[/tex]
and then you can use
[tex]\frac{d^2y}{dt^2}= He \frac{dx}{dt}[/tex]
to find y.
