Special Relativity 2-D Collision Problem
The discussion focuses on a special relativity problem involving a particle of mass M at rest that decays into three identical particles of mass m. Two particles travel at relativistic speeds of 4c/5 and 3c/5 in the -x and -y directions, respectively. The third particle's speed is calculated to be 0.9c, and the mass ratio M/m is determined to be 5.21. The solution employs conservation of momentum and energy principles, confirming that the components of relativistic momentum are equal.
  • Understanding of special relativity concepts, particularly momentum and energy conservation.
  • Familiarity with relativistic equations, specifically ρ = mvγ and E = mc²γ.
  • Knowledge of vector decomposition in two-dimensional motion.
  • Ability to solve quadratic equations and manipulate algebraic expressions.
  • Study the implications of relativistic momentum in multi-particle systems.
  • Learn about the Lorentz factor (γ) and its role in relativistic physics.
  • Explore two-dimensional collision problems in special relativity.
  • Investigate energy conservation in particle decay scenarios.
Students and educators in physics, particularly those focusing on special relativity, particle physics, and momentum conservation principles.
wuphys
This is my first time posting here, so please let me know if I do not have the proper format.
A particle of mass M is at rest in the laboratory when it decays into three identical particles, each of mass m. Two of the particles have velocities and directions as shown (one travels in the -x direction with a speed of 4c/5 and another travels in the -y direction with a speed of 3c/5. Calculate the direction and speed of the third particle (shown on the diagram moving with +x and +y components at some angle above the x axis) and find the ratio M/m.
I'm not sure (1) if the way I solved for v and the ratio is correct and (2) how to find the direction of the third particle. I originally solved it by saying the components of momentum are equal, but I don't think that would be correct because it is relativistic. Any help would be greatly appreciated!
ρ = mv[itex]\gamma[/itex]
E = mc2[itex]\gamma[/itex]
By conservation of momentum, ρi = ρf, so:
0 = (3/4)mc + (4/3)mc + v3[itex]\gamma[/itex]3
v3[itex]\gamma[/itex]3 = -(3/4)c - (4/3)c
After plugging in gamma to solve for v3:
v/sqrt(1-v2/c2) = -(25/12)c
v = +/- sqrt(c2/((144/625) + 1))
v = 0.9c
By conservation of energy, Ei = Ef, so:
Mc2 = (5/4)mc2 + (5/3)mc2 + 2.294mc2 where 2.294 is [itex]\gamma[/itex]3 (found using v solved for above)
so M = 5.21m
M/m = 5.21
Never mind, I think I got the answer. The components of relativistic momentum are just equal.
  • · Replies 36 ·
  • · Replies 35 ·
  • · Replies 28 ·
