Can Cooling a Room With a Car Radiator Work?
  • Thread starter Thread starter armoghan
The discussion revolves around the feasibility of using a car radiator to cool a room. Participants explore the concept of circulating cold water through the radiator, utilizing an electric pump and fan setup, and consider alternative cooling methods and materials.
  • Exploratory, Technical explanation, Debate/contested
  • One participant proposes using a car radiator with an electric pump to circulate cold water for cooling a room.
  • Another participant questions how the water will be cooled, prompting a discussion on the use of ice initially and potentially a compressor later.
  • A participant raises concerns about the practicality of sourcing ice, comparing its heat capacity to that of a small window air conditioning unit.
  • There is a humorous exchange regarding the source of water, with one participant suggesting that the availability of water may depend on costs and whether it is consumed in the cooling process.
  • Another participant suggests that using a bowl of ice with a fan blowing over it may be more effective than the radiator setup.
Participants express differing views on the feasibility and effectiveness of the proposed radiator cooling method, with no consensus reached on the best approach or materials to use.
Participants have not fully explored the assumptions regarding the cooling capacity of ice versus traditional air conditioning units, nor have they resolved the practicalities of sourcing ice or water for the proposed system.
armoghan
Can it possible?
Guys, i going to share an idea with professionals. i have a plan to cool my room by using car radiator. an electric pump circulate the cold water in the radiator and the fan mounted back with radiator will pass the air through the radiator.
i just want to ask you people that is it feasible? if it is... then what is your comments about its performance. what type of liquid should i use instead of water for this project.
any suggestions...
How do you intend to cool the water that you are circulating?
in start i am going to use ICE... if i succeed then i can use a small compressor
Where are you getting the ice? Not a freezer in the room I hope?
Have you compared the heat capacity of a bag of ice to the capacity of a small window AC unit?
Where he is getting the water just may depend on if he has to pay for it.
Freezer in the room. LMAO. Good one Russ, hadn't thought of that.
Many apartment complexes would give you water for free, but here the water isn't being consumed so it isn't relevant. But free or not (not), I'm considering using tap water for evaporative cooling in my house.
If you have a source of cheap ice then simply putting it in a bowl and letting the fan blow over it will be a lot more effective then chilling the water and passing it through a radiator.
  • · Replies 24 ·
  • · Replies 19 ·
