What causes liquid to rise in a capillary tube?
The rise of liquid in a capillary tube is primarily caused by surface tension, not air pressure. Surface tension allows the liquid to climb above the surface due to cohesive and adhesive forces acting at the liquid-solid interface. The contact angle plays a crucial role; if it exceeds 90°, the solid surface is hydrophobic, causing the liquid to fall instead of rise. This principle is also applied in damp-proofing injections that line capillaries in bricks with a hydrophobic material.
  • Understanding of surface tension in liquids
  • Familiarity with capillary action principles
  • Knowledge of contact angle and its implications
  • Basic concepts of hydrophobic and hydrophilic materials
  • Research the physics of surface tension in liquids
  • Explore capillary action in various fluids and materials
  • Study the effects of contact angle on liquid behavior
  • Investigate applications of hydrophobic materials in construction
Students of physics, engineers working with fluid dynamics, and professionals in construction and material science will benefit from this discussion.
AudioFlux
This question struck me when i was watching a liquid rise in a capillary tube. I'm curious to know from where the energy gets transferred to the liquid to rise above the surface. Well, one possible explanation that i can think of is air pressure. Though, it can be a possible reason only if the other end is closed (i don't remember if it was open or closed). So am i on the right track?
Hi AudioFlux! :smile:
No, it's surface tension, see …
http://en.wikipedia.org/wiki/Capillary_action#Height_of_a_meniscus
http://en.wikipedia.org/wiki/Wetting
http://en.wikipedia.org/wiki/Contact_angle :wink:
(if the contact angle is greater than 90°, the solid surface is hydrophobic, and the liquid will fall
this is how those damp-proofing injections work, they line the capillaries in the bricks with a hydrophobic lining)
  • · Replies 22 ·
56K
9K
