Understanding Electric Field Flux: Explained with Physical Interpretation
The discussion revolves around the physical interpretation of electric field flux through a closed surface, exploring its analogy to fluid flow and addressing confusions arising from different interpretations in various contexts, including electrostatics and nuclear physics.
  • Homework-related
  • One participant compares electric flux to fluid flow, suggesting that the flux integral represents a volume passing through a surface per second.
  • Another participant describes net flux as the sum of electric field lines entering or exiting a volume, noting that the net flux is zero until a charge is enclosed within the volume.
  • A participant presents a homework problem involving the flux of a charge through a disc and seeks to derive a relationship between the radius of the disc and the distance from the charge.
  • Concerns are raised about the analogy of electric flux to fluid flow, with some participants expressing that it may imply movement through the area, which they find misleading.
  • One participant references a textbook that presents conflicting analogies for electric flux and field strength, leading to confusion regarding definitions in different contexts.
  • Another participant attempts to clarify the concept of electric fields, emphasizing that they describe forces experienced by charges and are abstract representations rather than physical entities.
Participants express differing views on the usefulness of analogies for electric flux, with some finding them helpful while others do not. There is no consensus on the best interpretation of electric flux, and confusion remains regarding the definitions presented in different contexts.
Participants highlight limitations in understanding due to varying definitions of flux in different fields, such as electrostatics and nuclear physics, and the potential pedagogical drawbacks of certain analogies.
zezima1
Can anyone tell me the physical interpretation of the flux of an electric field through a closed surface. I think I do understand what flux is: Like in a water pipe a flux integral over the surface of the pipe would be the volume of water passing through the surface per second. What is the electric field dotted with the area? I've seen things like: It's the number of field lines passing through etc. but I don't like that picture, since field lines are not really a physical thing to me.
The flux is the electric field lines passing through the volume. The net flux is the sum of all field lines going in or out of a volume. For example, if you are at a great distance of a charged particle, the electrical field lines will be parallel. If you now draw a volume with 4 sides parallel to the flux direction, than the remaining two sides will cancel out (E1*n1dA1+E2n2dA1, where E1=E2, dA1=dA2 and n1=-n2), so there's no net flux in or out of that volume. When you move closer to the charge, however, the picture will change, but while the geometry changes the net flux will still be zero until you move so close to the charge that the charge is actually enclosed within your volume. When this happens the field lines no longer cancel each other out. There will be field lines going to the outside at all 6 sides of your volume. The net flux going in or out a volume is proportional to the electric charge in the volume.
HI Friendz,
I've confusion in solving a question. Please help me out. The question is as follows.
There a positive charge q placed 'a' distance far from the center of a disc of radius 'r', on its axial line. The flux of charge on the disc is 1/4th of the total flux of the charge in the space. then deduce a relation between 'r' and 'a'.
the answer is "r = a / √3"
z. As you say, if v is the velocity of fluid flow, v.dA is the volume of fluid passing through dA per second, i.e. the flux of fluid. So the definition of electric flux as E.dA is exactly analogous. For my taste, that's as far as I want to take the analogy; even this has the pedagogic drawback that it might suggest that something is moving through the area in the case of the electric field. I certainly don't find 'number of field lines passing through an area' very helpful.
I'm not sure you're going to find any deeper interpretation of the definition of electric flux. The definition proves its worth as soon as you state Gauss's Law.
Th. A couple of hints...
(1) The flux from q that passes through the disc will pass through the spherical cap shown
in my diagram – hope I've got the set-up right.
(2) I've given you a formula (which you'll need) for the area of a spherical cap. You should try and prove it by integration.
With this information and a bit of algebra and elementary trig, you should be able to solve the problem. Incidentally, my answer wasn't quite the same as the one you gave. Quite possibly a slip on my part.
This isn't the only way to do the problem. You can integrate directly the flux passing through the disc, dividing the ring into annuli. You mustn't forget that the field strength changes from annulus to annulus, and so does the angle between the disc surface and the field.
Edward M. Purcell's book "Berkeley Physics Vol2: Electricity & Magnetism" has me confused on the concept of electric flux.
On page 22 he has a diagram of flowing water implying (like zezima1 says above) that electric flux is analogous to the volume of fluid passing through a surface per unit of time--such as m^3/s
However, on page 24 he talks about bullets. He writes that field strength E is analogous to intensity of particle flow in bullets per unit area per unit time--bullets/m^2/s. He goes on to say that the flux of bullets through any surface surrounding the gun "is just the total number emitted per unit time" (bullets/second).
This is VERY confusing to me as I'm more familiar with neutron physics where the definitions are the OPPOSITE of what Purcell is describing. For instance a neutron source strength (Q) is measured in neutrons/second while neutron flux (phi) is rated in neutrons/cm^2/s.
I would appreciate some help in finding a way forward as this is a huge impasse.
I'm not that familiar with nuclear physics, but I'd like to try to explain it with electrostatics.
The need to define an electric field has come from the observation that charges experience forces from other charges, they attract or repulse. The electric field is also defined as the force per unit charge. That's also all it is. The electric field is just a description of what forces charges would experience on various locations. The electric field is more of an abstract thing and not really a concrete physical thing. When we define the electric field as the force per unit charge it also means that there's nothing really moving around. Rather it's a description of how something (a charge) might move around when placed in the field. I think this is different from your nuclear flux and nuclear source strength.
In electrostatics we often talk of field lines which we use to represent the electric field. Electric field lines are as abstract as the electric field, but they are of great use in visualizing what happens. Now the field strength can indeed be described as something like bullets. It is important to note that it is a property of an area whereas the flux is a property of volume. Field strength describes how many field lines go through a certain area while electric flux describes how many field lines go in/out a volume.
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 35 ·
