Proof of symmetries in electrostatics
The discussion revolves around the mathematical proof of symmetries in electrostatics, particularly focusing on the direction of the electric field for spherical and cylindrical charge distributions. Participants explore the implications of rotational and reflection symmetries on the electric field's characteristics, as well as the conditions under which these symmetries hold.
  • Some participants propose that the electric field must be radial for a spherical charge distribution due to its rotational invariance.
  • Others argue that for a conducting cylinder or sphere, the electric field cannot have components parallel to the surface, leading to a perpendicular electric field.
  • A participant suggests that a mathematical proof should demonstrate that the electric field direction is determined by symmetry without relying on physical explanations.
  • Another participant mentions that if the charge is rotationally symmetric, the electric field must also be symmetric, implying no tangential components can exist.
  • One participant presents a mathematical approach using the curl of the electric field to show that the radial component is uniform across the surface of a sphere.
  • Some participants note that the discussion lacks clarity on whether the charge distributions are conducting or static, which may affect the conclusions drawn.
  • There is mention of alternative proofs involving symmetry arguments, but these are not elaborated upon in detail.
  • A participant introduces a mathematical expression related to the divergence of the electric field, suggesting it can be used to show certain properties of the electric field components.
Participants express differing views on the necessity and nature of mathematical proofs for the electric field's direction. While some agree on the role of symmetry, others emphasize the need for specific conditions (like the charge being static or conducting) to validate their claims. The discussion remains unresolved regarding the best approach to prove these properties.
Participants highlight the importance of defining conditions such as whether the charge is static or conducting, as these assumptions significantly influence the arguments presented. There is also a lack of consensus on the sufficiency of symmetry arguments alone to establish the electric field's characteristics.
Trifis
I need a mathematical proof that should indicate the following: The direction of the electric field must be radial, for a spherical charge distribution to remain invariant after applying a rotation matrix to its field.
Analogously how can we prove that the electric field of a infinite cylinder is perpedicular to its surface?
Moreover, consider our augmentation at the boundary value problem of electrostatics. Dirichlet's condition was once more taken as granted, of course there not due to some symmetry but nevertheless the principle remains the same!
In other words, why is the electric field of the symmetric objects the way it is? Is it an experimental result or just the result of a superposition, which could be deducted? After all, all the great consequences of the laws of electrostatics are based on these initial "symmetry" assumptions! E.g. we could not calculate the electric field of a sphere with Gauss's law without "guessing" its direction!
I need maths in order to unravel this symmetry mystery...
Trifis said:
Analogously how can we prove that the electric field of a infinite cylinder is perpedicular to its surface?... E.g. we could not calculate the electric field of a sphere with Gauss's law without "guessing" its direction! I need maths in order to unravel this symmetry mystery...
The solution is simple. If the cylinder or sphere is conducting, then there can not be any electric field parallel to the surface. If there were, then there would be surface currents to redistribute the charge. Thus the electric field (if any) has to be perpendicular to the surface.
I think the OP wants a mathematical proof, i.e., without understanding what electric field is and how it interacts with charges, prove that it is in the radial direction due to rotational invariance, since its source is rotationally invariant.
All the OP needs to know is [itex]\overrightarrow{J}=\sigma\overrightarrow{E}[/itex]. If there is a component of electric field that is parallel to the surface, then there is a surface current. Therefore the electric field has to be perpendicular to the surface.
@Bob S I don't mean to become ungrateful, but what I need to know is what I'm asking for (bold text). I'm already aware of the physical explanation.
I'm pretty sure, that a theorem of the following form can be found in the bibliography:
D[itex]\vec{E}[/itex](D[itex]\vec{r}[/itex]) = [itex]\vec{E}[/itex]([itex]\vec{r}[/itex]) [itex]\Rightarrow[/itex] [itex]\vec{E}[/itex]([itex]\vec{r}[/itex]) = E([itex]\vec{r}[/itex])[itex]\vec{e_{r}}[/itex]
That's what I'm looking for!
I think first that you have to state that the surface of the sphere is conducting, and that the charge is static (no surface currents). Then using J = σE , you can show that if there are no surface currents, Eθ=Eφ=0. Thus there can be only a radial electric field Er.
Then you can use the 3 components of [itex]\left(\nabla\times \overrightarrow{E} \right) =0 \space[/itex] to show that [itex]\frac{\partial E_r}{\partial \theta} = \frac{\partial E_r}{\partial \varphi}=0[/itex]. Thus Er is the same everywhere on the surface of the sphere: Curl E in spherical polar coordinates is
[tex]\left(\nabla\times \overrightarrow{E} \right)_\theta=\frac{1}{r\sin\theta}\frac{\partial E_r}{\partial \varphi} -\frac{1}{r}\frac{\partial\left(r E_\varphi \right)}{\partial r}=0[/tex]
[tex]\left(\nabla \times \overrightarrow{E}\right)_\varphi=\frac{1}{r}\left(\frac{\partial\left(r E_\theta \right)}{\partial r} -\frac{\partial E_r}{\partial\theta } \right) =0[/tex]
[tex]\left(\nabla \times \overrightarrow{E}\right)_r = \frac{1}{r\sin \theta}\left(\frac{\partial\left(\sin\theta E_\varphi \right) }{\partial \theta}-\frac{\partial E_\theta}{\partial \varphi} \right)=0[/tex]
Well, you've mathematically elaborated your argument, namely the fact that the condition for an electrostatic equilibrium leads to the determination of the direction of the electric field.
That is appreciated.
BUT, you should be aware that there is also another proof of this, involing only symmetries rotation matrixes and reflections on planes...
I would have to compromise myself, that I'll never see that beautiful proof again:frown:
If the charge is rotationally symmetric, so is the field. Therefore, the field cannot have tangential components. (For any tangential component at any point, a rotation along the axis connecting that point and the origin will change that component.) For cylinder, instead of considering rotational symmetry, consider reflection symmetries about the x-y plane and any plane containing z axis, similar conclusion can be made about the tangential components.
BTW, the OP didn't even mention there's a conductor.
[itex]\nabla . E(r,\phi,\theta)=\rho(r)/\epsilon[/itex]
According to my calculation , if we define vector filed F as :
[itex]F(r,\phi,\theta)=\frac{\partial E(r,\phi,\theta)}{\partial \phi }[/itex]
then we have
[itex]\nabla . F=0[/itex]
and
[itex]\nabla × F=0[/itex]
which mean [itex]\frac{\partial E}{\partial \phi }=0[/itex]
I think you can prove the same for [itex]\frac{\partial E}{\partial \theta }[/itex].
  • Sticky
  • · Replies 0 ·
  • · Replies 19 ·
9K
