Confused with working out the span of a set of vectors in R^2
The discussion centers on the span of the set S, defined as all vectors x=(x₁, x₂) in ℝ² where x₁=1. The conclusion is that span S equals ℝ², as any vector in ℝ² can be expressed as a linear combination of vectors in S. The confusion arises from the conditions where x₁ is both equal to 1 and 0, which are clarified as separate cases to demonstrate that all points in ℝ² can be represented using linear combinations of vectors from S.
  • Understanding of vector spaces and spans in linear algebra
  • Familiarity with linear combinations and their properties
  • Basic knowledge of the real number system ℝ
  • Proficiency in mathematical notation and expressions
  • Study the concept of vector spans in linear algebra
  • Learn about linear combinations and their applications
  • Explore the properties of vector spaces in ℝ²
  • Investigate cases of linear dependence and independence of vectors
Students and educators in mathematics, particularly those focusing on linear algebra, as well as anyone seeking to deepen their understanding of vector spaces and spans in ℝ².
gilabert1985
Hi everyone!
I have the following problem which I don't understand... It is already solved, but there are three questions I have regarding it.
The problem says: "Let S be the set of all vectors [itex]x=(x_{1}, x_{2})[/itex] in [itex]\Re^{2}[/itex] such that [itex]x_{1}=1[/itex]. What is the span of S?"
And here is the answer that has me so confused...
"[itex]span S = \Re^{2}[/itex] because [itex](x_{1}, x_{2})=x_{1}(1, x^{-1}_{1}x_{2}[/itex] when [itex]x_{1}\neq0[/itex]
and [itex](x_{1}, x_{2})=(1, 0)-(1, -x_{2})[/itex] when [itex]x_{1}=0[/itex]."
But I don't understand the first line... why does it say when [itex]x_{1}\neq0[/itex] if [itex]x_{1}[/itex] is supposed to be equal to 1?
And in the second line, the same... why is [itex]x_{1}=0[/itex]?
So yeah, I understand they are linear combinations and all that, but for the condition given ([itex]x_{1}=1[/itex]), I don't understand how this answer satisfies it.
The points (x1,x2) in the lines that are confusing you are not points in S, but points in R2, which it then shows how to represent as linear combinations of points in S
Since you can't rewrite ##x_2## as ##x_1 x_1{}^{-1}x_2## when ##x_1=0##, you have to consider the case ##x_1=0## separately.
  • · Replies 25 ·
