Why Isn't the Moon's Shadow Line Perpendicular to the Sun-Moon Line?
  • Context: Undergrad
  • Thread starter Thread starter johann1301
    Moons Sun
The discussion revolves around the observation that the Moon's shadow line does not appear perpendicular to the line connecting the Sun and the Moon. Participants explore potential explanations for this phenomenon, including atmospheric effects, perception errors, and the implications of light travel time.
  • One participant notes that the shadow line on the Moon appears straight, leading to a conclusion about the angle between the Moon and Sun, but questions why it is not perpendicular to the Sun-Moon line.
  • Another participant explains that the shadow on the Moon is a circle on a sphere, which appears straight from a certain perspective, and questions the assumption of perpendicularity.
  • A participant raises the issue of measurement accuracy, suggesting that time zone differences might affect observations.
  • One participant argues that atmospheric refraction significantly alters the perceived position of the Sun, especially during sunrise and sunset, affecting the apparent alignment of the Moon's shadow.
  • Another participant challenges the relevance of light travel time differences, asserting that the refraction explanation is more pertinent to the observed phenomenon.
  • A later reply acknowledges the confusion regarding light travel time and suggests that it may not significantly impact the perception of the shadow's position.
  • One participant references an external source suggesting that the phenomenon may be a perception error, recommending visual aids to assess the alignment accurately.
  • Another participant expresses agreement with the idea that the terminator may not be straight, indicating this could resolve the observed discrepancy.
Participants express differing views on the causes of the observed phenomenon, including atmospheric refraction and perception errors. No consensus is reached regarding the primary explanation.
Some participants mention the potential impact of light travel time on observations, but there is uncertainty about its significance relative to atmospheric effects and perception issues. The discussion includes references to external sources for further exploration.
johann1301
So I'm watching the sky at daytime, and i see the moon. The shadow on the surface of the moon goes in a straight line. I therefore conclude that the angle of MeMoonSun must be 90 degrees. But a peculiar thing shows; The shadow line on the moon is not perpendicular to the straight line between the sun and the moon! This is strange...
considering a basket ball and a flashlight, i cannot get the same result.
Why is this? Is it because of General relativity?
Astronomy news on Phys.org
The shadow line is a circle on the surface of a sphere. When viewed from within the plane of this circle it looks straight (half-moon). This circle is always in a plane perpendicular to the line between the moon and the son. Why don't you think it's perpendicular?
How far out is your measurement? Could it be because you are using the time zone time and not local local time?
Anyone who spends time outdoors will have noticed this - the Moon's shadow looks wrong for the apparent position of the Sun. This is very noticeable at Sunset and Sunrise when the Moon is much higher in the sky. The discrepancy is caused mostly by the refraction of light through the density gradient of the atmosphere.
The atmosphere bends light as the light goes through the increasing density of the air at different altitudes. This effect is much greater than you might imagine. I was at a concert where they turned on large lasers directed up into the night sky at about a 45 degree angle to the horizon. When the beams came out they bent down to the horizon... the beams were surprisingly visibly curved.
This is why if you time the Sun across the sky it seems to rise in the morning and set in the evening at a slower pace across the sky than at midday. When you think you are seeing the Sun at low sunset, it is geometrically already below the horizon. The air is bending the light around the edge of the Earth to continue showing you the Sun. Same thing at Sunrise, you see the Sun's image as light bending around the Earth before its true geometrical line of sight is above the horizon.
You are also seeing the Moon from about one second ago, you are seeing the Sun from about eight minutes ago, as is the Moon and its shadow. This is a small effect. The main one is the refraction of the atmosphere.
So basically, you are seeing the Sun in the wrong place. The Sun's correct geometric position is on a line perpendicular to the edge of the Moon's shadow... with some small error due to the shadow itself representing the Sun's position from eight minutes prior.
Does that really make a difference? You see one interval of the Sun's emitted light at the same time as it arrives at the Moon (more or less) There is only a second's difference in arrival time of the sunlight and the reflected light from the Moon. The eight minutes of delay is not relevant because there is always some light available just over the Horizon (It doesn't arrive as a 'flash'). It could have come from twice the distance and the effect would still be the same. And why would the arrival time difference from the Moon make a difference? Also, your proposed effect would work one way when the Moon is overhead at sunrise and another way, two weeks later, when it's overhead at sunset.
The refraction explanation is the right one to go for.
I just stepped out and that very question began sneaking its way into my thinking - that the eight minutes would not matter. I resolved to edit my post when I returned, but was glad to see you caught it already.
This transit time thing can be confusing. It's relevant for things like observations of the orbits of the moons of Jupiter. Before the advent of good chronometers for navigation, I believe they had tables of the transits of those moons to give mariners a time reference. Thank god for GPS, eh?
The question was asked here:
http://astronomy.stackexchange.com/questions/1750/sun-moon-earth-anomaly
They suggest it is a perception error and you should use a yard-stick as a visual help to check if there really is a significant offset. A small offset can be explained by refraction but that amount would hardly be perceivable without visual helps.
Reposting the answer with references because the other site will shut down soon
Rory Alsop said:
Have checked back on various sources and I think as @Keith has said, the perpendicular bisector does always point directly at the sun, no matter what you are perceiving.
Have a look at this University of Nebraska page to see why this always has to be the case.
Minnaert's "The Nature of Light and Colour in the Open Air" also discusses these and explains why it is a perception problem. Use a straight edge or a taut piece of string to prove to yourself that it is actually true.
This is suggesting that the apparently straight terminator is not actually straight. I could believe that easily. That probably solves our problem.
Brill!
  • · Replies 23 ·
10K
9K
