Simulating a system of levers with opposing force?
  • Context: Graduate
  • Thread starter Thread starter kperry1408
    Force Opposing System
The discussion revolves around simulating a system of levers connected at one end, with the other ends subject to resistive forces. Participants explore how to determine the motion of the system when the angle between the levers is altered, considering factors such as friction and moment of inertia.
  • One participant describes a system of two bars connected at one end and subject to opposing forces, seeking to understand the resulting motion when the angle between the bars changes.
  • Another participant questions the meaning of "maximum threshold" in the context of the resistive forces acting on the bars, suggesting that the mass distribution and speed of angular change affect the motion.
  • A participant explains that the maximum force of friction is determined by the coefficient of friction and the normal force, proposing that both arms should move proportionally when turned relative to each other.
  • Another participant argues that if the force on one arm is less than the friction, that arm will not move, emphasizing that a force greater than friction is needed for motion.
  • There is a debate about the nature of friction, with one participant asserting that if friction were independent of velocity, an object would slide indefinitely after an initial push, while another counters that friction acts to bring the object to rest.
  • Several participants discuss the distinction between static and kinetic friction, with one noting that kinetic friction opposes the velocity vector and is dependent on it, while static friction opposes the net force vector.
  • Another participant clarifies that kinetic friction remains constant in magnitude and direction while the object is moving, regardless of its velocity, unless nonlinear effects are considered.
Participants express differing views on the behavior of friction, particularly between static and kinetic cases, and whether the motion of the levers is dependent on the forces acting on them. The discussion remains unresolved regarding the implications of these factors on the motion of the system.
Participants reference various assumptions about the system, including the moment of inertia of the levers and the nature of the resistive forces, which may not be fully defined or agreed upon.
kperry1408
I'm trying to simulate the following situation:
Two bars are attached to each other at one end by a device which controls the angle between them. The opposite end of each bar (the end not attached to the device) is subject to a resistive, motion-opposing (friction-like) force, each with an equal maximum threshold.
How can I determine the motion (rotational and translational) that this object undergoes when the angle between the bars is changed from alpha to beta? I am planning to describe the position of the object using the position of the junction between bars and the direction that each bar currently points.
I.e. if the object is initially centered at (0,0) with bar A (length Ra) pointing to ∏ and bar B (length Rb) pointing to 0, and the angle from A to B is changed from ∏ to ∏/2, what will the new position and angles be?
Thanks in advance, I know it's a long question :)
What do you mean with "maximum threshold"?
It depends on the mass distribution of your system, the friction and the speed of the angular change.
Usual case: If you do it slow enough, just one arm moves. If you change your angle fast enough, both move.
Similar to friction, i.e. in the case of friction the maximum value is the coefficient of friction multiplied by the normal force. The friction opposes all motion however it can only exert that certain maximum force so when a force larger than that is put on the object the object will still move, just not as rapidly. In this case I would assume that the coefficient were the same for static and kinetic cases just to simplify things.
And let's say we are already given the moment of inertia of each lever, Ia and Ib. And the only frictional force is the one stated above. Shouldn't both arms turn proportionally to each other? I don't see why just one would move when they are being turned relative to each other, and the resistive force is the same for each..
If the force on one arm is smaller than the friction, it does not move at all - friction on a surface is usually independent on the velocity (at least as approximation). You have to apply a force which is larger than friction to get it moving.
If friction on a surface were independent of velocity than an object would continue sliding forever if you gave it an initial push that were stronger than friction..? Or it would first cause it to stop, then turn it around and accelerate it in the other direction which is also clearly not the case
No, as soon as your push ends, the force would slow the object down, and the object would come to rest (and stay at rest) after a finite time and distance.
F=m*a
F=m*a
Right but why does the friction force stop pushing when the object comes to rest? It has to depend on velocity to some extent. It may be that it has a constant value which points in the direction opposite of the velocity vector (which would be a zero vector when velocity is zero) but is still has to be dependent on velocity
As you already said, it is a maximal force. If you apply a smaller force (can be 0), this is just transferred to the ground and the object does not move. If the force is too large, only this maximal amount is transferred and the object gets accelerated.
This is ignoring the difference between static and dynamic friction here.
Yeah I agree that static friction behaves this way. I guess I should have been more specific but kinetic friction is primarily what I'm interested in for this case. Kinetic friction does rely on velocity because it opposes the velocity vector, whereas static friction just opposes the net force vector.
This is the part about kinetic friction. It is always there if the object is moving, it is antiparallel to the velocity and with the same magnitude (independent of the velocity !=0), neglecting nonlinear effects.
  • · Replies 19 ·
  • · Replies 31 ·
