Interplanetary Trajectory Calculation
  • Context: Undergrad
  • Thread starter Thread starter MattRob
    Calculation Trajectory
This discussion focuses on calculating interplanetary trajectories for a Mars mission using algebraic equations, specifically the vis-viva equation and Hohmann transfer orbits. The user aims to determine Mars transit time for non-Hohmann transfer orbits by approximating the flight path as a section of an ellipse. Key concepts include true anomaly, eccentric anomaly, and mean anomaly, with emphasis on using Newton-Raphson iteration to solve Kepler's equation for eccentric anomaly. The discussion highlights the importance of understanding elliptical integrals and the relationship between various anomalies in orbital mechanics.
  • Basic calculus (single variable)
  • Understanding of the vis-viva equation
  • Familiarity with orbital mechanics concepts such as true anomaly and eccentric anomaly
  • Knowledge of Kepler's laws of planetary motion
  • Research Newton-Raphson iteration for solving Kepler's equation
  • Study elliptical integrals and their applications in orbital mechanics
  • Learn about the vis-viva equation in detail and its derivations
  • Explore advanced topics in orbital dynamics, including perturbation theory
Aerospace engineers, astrophysicists, and hobbyists interested in orbital mechanics and interplanetary mission planning.
MattRob
Hello,
For something of a hobby of mine, I'm looking at different interplanetary trajectories for a Mars mission.
I've got a somewhat interesting case;
I only know basic calculus of a single variable (taken calculus 1), so I can't do the more in-depth multivariable and (I think) vector calculus required for true calculation of interplanetary trajectories, so for now, I'm sticking to algebraic equations which assume only two bodies and instantaneous Δv. (such as the vis-viva equation, and equations given on wiki for things like hohmann transfer and flight path angle)
So, here's the problem;
I want to be able to calculate Mars transit time for non-hohmann transfer orbits. The method I'll use is to approximate the interplanetary flight path with a section of an ellipse, find the velocity and distance to get time for the flight.
The first step, is calculating the speed. That's rather simple, just an integral of the vis-viva equation with Δv/Δr, divided by the Δr to get average velocity.
The second step, finding the distance, is where I need some help.
The problem, from what I've seen, is finding the arc length of an ellipse from one point to another.
Most of the answers I've seen from looking around on the web are a bit above me, though, lol. But it looks like it can be done with just single variable calculus, so I'll give it a shot.
Arc length along an ellipse is calculated by an elliptical integral (and now you have a term to google).
Elliptical integrals are not the way to solve this problem, however. You need to solve for time of flight and and an angle called true anomaly. This is the angle between the directed line from the ellipse focus (e.g., the Sun) to the periapsis point and the directed line from the focus to the current point on the orbit. There is a related angle called eccentric anomaly. True anomaly ν (Greek nu, but sometimes written as θ, and other times f) and eccentric anomaly E are related by the orbital eccentricity e via
[tex]\tan\frac{\nu} 2 = \sqrt{\frac{1+e}{1-e}}\tan\frac E 2[/tex]
Why this new term E? The answer is Kepler's equation, which relates eccentric anomaly E and yet another "anomaly" called mean anomaly M by
[tex]M = E - e\sin E[/tex]
So what's this M? The reason for using the mean anomaly is that it grows linearly with time:
[tex]M(t) = M(t_0) + n (t-t_0)[/tex]
That n is called the mean motion. It is given by [itex]n=2\pi/T[/itex], where T is the orbital period. Another equation for the mean motion is [itex]n=\sqrt{GM/a^3}[/itex], where this M is the mass of the central object. Yet another equation is [itex]n=\sqrt{\mu/a^3}[/itex], where [itex]\mu=GM[/itex] is the standard gravitational parameter for the central object. Word of advice: Use μ (mu) rather than G*M. This disambiguates the meaning of M (is it mean anomaly or central mass?) and it is more accurate. We only only G to 4 decimal places or so, and the same for the mass of the sun. Compare that to the ten decimal places to which we know product G*M for the sun. In fact, the mass of the sun is determined by dividing the sun's gravitational parameter by G.
Calculating the mean anomaly M at some time is a straightforward calculation if you know the true anomaly at that same time or if you know the mean motion and you know the mean anomaly at some other time. Calculating the true anomaly if you know the mean anomaly isn't so simple. You will have to calculating the eccentric anomaly and then calculate the true anomaly from the eccentric anomaly. The problem is that there is no nice simple formula that is the inverse of Kepler's equation. There is no such formula in the elementary functions. One widely used approach is to use Newton-Raphson iteration to solve Kepler's equation for E given M and e.
  • · Replies 25 ·
  • · Replies 138 ·
9K
  • · Replies 18 ·
  • · Replies 60 ·
