Johnson noise and a magnetic field
The discussion centers on the effects of an external magnetic field on the frequency spectrum of Johnson noise, particularly in the context of electrolytic solutions and water. Participants explore the complexities of charge transport phenomena and the implications for experimental measurements.
  • Experimental/applied
  • One participant suggests that the frequency spectrum of Johnson noise may not change significantly with a magnetic field since it primarily alters the direction of electron motion rather than their speed.
  • Another participant questions whether the focus is on Johnson noise in resistors or in semiconductors, noting that magnetic fields are typically applied to Hall probes, which are semiconducting and may exhibit excess 1/f noise.
  • A participant specifies interest in the effects of an external magnetic field on water and electrolytic solutions.
  • Concerns are raised about the complexity of charge transport phenomena in electrolytes, which are described as highly non-linear and coupled to diffusion and thermal conduction, suggesting that simple conductivity measurements may not capture the full physics.
  • One participant expresses frustration over the complexity and suggests that measuring noise in a solid might be simpler than in electrolytes.
  • Another participant clarifies that while standard setups exist for measuring conductivity in electrolytes, measuring noise involves fluctuations in voltage drop, and emphasizes the importance of understanding the relationship between measurements and theoretical calculations.
  • It is noted that pure distilled water is a good insulator and that the conductivity of electrolytes is highly dependent on concentration, which may affect the applicability of Johnson noise concepts.
  • Differences between the behavior of ions in magnetic fields compared to free electrons are highlighted, particularly due to the mass and mobility of ions.
Participants express differing views on the applicability of Johnson noise concepts to electrolytes and the impact of magnetic fields, indicating that multiple competing perspectives remain without a clear consensus.
The discussion highlights limitations in understanding charge transport in electrolytes, the dependence on specific conditions such as concentration, and the unresolved nature of how Johnson noise applies outside of metal conductors.
Isaiah Gray
Would the frequency spectrum of Johnson noise change at all when a magnetic field is applied? My guess is not much, since the field changes only the direction of motion of the electrons, not their speed.
Are you interested in Johnson noise in resistors, where the original noise was identified? I am asking because magnetic field is usually applied to Hall probes, which, in turn, are semiconducting. But, there is excess [itex]1/f[/itex] noise in semiconductors.
Yes; I am specifically interested in an external magnetic field applied to water and electrolytic solutions.
Oh my, this sounds as a pretty complicated problem. The charge transport phenomena in electrolytes are highly non-linear, so a simple conductivity cannot captured the whole physics. Besides, because ions have significant mass, charge transport is coupled to diffusion, as well as thermal conduction. A thermal fluctuation in any of these induces a fluctuation in electric properties. Besides, the geometry of the electrodes might be an important factor.
So I guess measuring noise in conductivity wouldn't tell me much then? Man, I just wanted a simple experiment with water and magnetic fields. Maybe if I measured noise in a solid, it would be easier.
No, you can do that. There are standard setups for measuring conductivity of electrolytes. Measuring noise refers to measuring fluctuations in voltage drop, however. From an experimental point of view, you need to be clear what you measure. From a theoretical point of view, I think the conductivity is used to express the fluctuations, and, is a more convenient quantity for calculations. Nevertheless, you need to be aware of the physical connection between what you measure and what is used in calculations.
But, when you say water, you have to bear in mind that pure distilled water is actually a very good insulator! The conductivity of an electrolyte is strongly dependent on the concentration.
You asked a question if the spectrum of Johnson noise would change if magnetic field is applied:
1) As far as I know, Johnson noise is specifically referred to metal conductors, where the charge carriers are free electrons. Electrolytes are radically different than this. Therefore, one should not expect the white spectrum to necessarily hold for electrolytes, although it might.
2) Magnetic fields affect ions differently than free electrons, mainly because of the large mass and low mobility of ions.
So, I just wanted to point out these differences.
