Enthelpy change for chemical reaction
The discussion revolves around the interpretation of enthalpy change (ΔH) for chemical reactions, specifically focusing on the decomposition of hydrogen peroxide and combustion of methane. Participants explore how ΔH values are presented and what they imply regarding the amount of heat generated during reactions, addressing both theoretical and practical aspects relevant to GCE O levels.
  • Homework-related
  • One participant questions whether ΔH=-98kJ/mol indicates that 2 moles of hydrogen peroxide produce 98kJ of heat, and if halving the equation would yield ΔH=-39kJ.
  • Another participant suggests that ΔH is typically given per mole, but the exact reference (mole of reaction or selected reactant/product) may vary.
  • There is confusion about the meaning of -98kJ/mol, with a participant expressing uncertainty about how to interpret it if not specified as per mole of a particular reactant.
  • A later reply clarifies that it is -98kJ per mole of hydrogen peroxide decomposed, acknowledging the ambiguity often present in such information.
  • Participants discuss the need for clearer wording in exam questions to avoid confusion about whether ΔH refers to a single reactant or the entire reaction.
  • One participant raises concerns about being at the mercy of the marker in multiple-choice questions and suggests a way to ask the examiner for clarification on the interpretation of ΔH.
Participants express varying levels of understanding and agreement on how to interpret ΔH values, with some suggesting it is per mole of a specific reactant while others highlight the ambiguity in exam questions. The discussion remains unresolved regarding the best approach to clarify such ambiguities in assessments.
Participants note that the interpretation of ΔH can depend on the specific wording of exam questions, and there is acknowledgment of the potential for ambiguity in how enthalpy changes are presented.
sgstudent
hi I'm taking GCE O levels so this might give you an idea of my level of chemistry. For a reaction like 2H2O2-->2H2O+O2 and the question tells me it has an ΔH=-98kJ/mol so does it mean that when 2 moles of hydrogen peroxide decomposes to form water and oxygen, the net amount of heat generated is 98kJ? So if i half the equation into H2O2-->H2O+1/2O2 the ΔH=-39kJ?
Thanks for the help!
Chemistry news on Phys.org
You are most likely right, although details may depend on the exact wording. ΔH is usually given per mole - either so called "mole of reaction", or a mole of selected reactant/product.
But usually which onr would it be? Like in the O levels? Thanks for the help Borek!
Since it tells you that ΔH=-98kJ/mol, the decomposition of 2 moles of hydrogen peroxide has ΔH=-196kJ.
I don't get it, what does the -98kj/mol even mean? I'm getting really confused here. What if they don't tell us whether it is per mole of something like they just tell you that its -98kJ/mol then what do I assume? Is it right to say if they tell you that its per mole of one of the reactants than its per mole of that reactants but if they don't than it could be as Borek said "mole of reaction". How do I tackle this issue? Thanks for the help!
I checked - it is -98kJ per mole of hydrogen peroxide decomposed.
Unfortunately you will find such ambiguous information way too often. In this case they probably mean "per mole of hydrogen peroxide decomposed", but your confusion is perfectly justified and it is not your fault. When in doubt - ask for clarification. During test you can write "I am assuming data given means -98kJ per mole of hydrogen peroxide decomposed" and follow from there - at least it will be easier for you to defend your solution if they meant something else.
So for example a question gives:
Methane, CH4, burns in excess oxygen to form carbon dioxide and water
CH4+2O2-->CO2+2H2O ΔH=&890 kJ/mol
Calculate the energy release when 2.4g of methanoic is burnt
In the answer that treated the per mole to be for the number of moles of CH4 when they did the mole calculation. So I'm guessing in exams they ought to make it clearer like saying: when 1 mole of methane burns completely it produces 40kJ of heat. Then they continue to write the information?
But four multiple choice questions then am I in a way in the mercy of the marker? If I were to ask the examiner for the information can I ask it like this:"I'm not very sure if they are trying to imply whether its one mole of (name of compound) being reacted or one mole of the entire equation reacted. can I assume that it refers to per mole of the entire equation?"
Yes. When it is about burning you can usually assume ΔH is given per mole of burnt substances, but in the case like
2KMnO4 + 5H2O2 + 3H2SO4 -> 2MnSO4 + K2SO4 + 5O2 + 8H2O
stating ΔH=xkJ/mol is meaningless.
That would be the correct way.
Thanks for the help Borek! :smile:
  • · Replies 37 ·
18K
  • · Replies 19 ·
11K
