Single and double precision matlab
  • Thread starter Thread starter sara_87
    Matlab Precision
The discussion centers around changing the default precision in MATLAB from double to single for all computations. Participants explore the implications of MATLAB's default settings and seek solutions for managing variable precision in their code.
  • Homework-related
  • One participant inquires about changing the default precision in MATLAB to single for all computations, expressing frustration with the current double precision default.
  • Another participant suggests that there is no way to change the default arithmetic for all operations in MATLAB, noting that variables are double precision by default. They propose defining variables as single precision from the start to achieve single precision outputs in operations.
  • A third participant acknowledges the limitation of this approach, especially for large codebases with many variables.
The discussion does not resolve the limitations of changing precision settings in MATLAB, nor does it address potential workarounds in detail.
sara_87
MATLAB uses double precision as default.
How can I change this to single? so that all computations will be made using single precision.
I went to:
file
preferences
virtual reality precision: floating point: single (I changed this from double to single)
However, my computations are still being made in double precision.
I don't want to change a single variable to single precision (this is done using single(A)) I want to change all computations.
thank you.
I do not believe there is a way to change the default arithmetic for all operations, as MATLAB variables are indeed double precision by default. Nevertheless, if you define variables to be single precision to begin with, then any operations between them will result in a single precision output.
oh right i see. thank you.
I know that's not a comforting answer if you have a large code with lots of variables -- sorry!
  • · Replies 17 ·
9K
