Prime Ideals: Abstract Algebra Example
  • Context: Graduate
  • Thread starter Thread starter naturemath
    Prime
The discussion revolves around the nature of certain ideals in the polynomial ring C[x1, x2, x3, x4], specifically whether they are prime ideals. Participants explore various examples and provide reasoning related to the properties of these ideals.
  • Some participants propose that the ideal (x1, x2) is a prime ideal because the quotient ring is an integral domain.
  • Others argue that the ideal (x1 x4 - x2 x3, x1 x3 - x2^2) is not a prime ideal, citing that certain elements can be expressed as combinations of others in the ideal without being contained in it.
  • There is uncertainty regarding the ideal (x1 x4 - x2 x3, x1 x3 - x2^2, x2 x4 - x3^2), with some participants suggesting it is prime due to its association with the irreducible twisted cubic, while others question this conclusion.
  • Some participants mention the relevance of specific polynomial equations in assessing the properties of the ideals.
  • One participant suggests considering primary decomposition as a method for analyzing ideals, questioning the systematic approach to such decompositions.
  • Another participant notes that many ideals can share the same zero locus, but only one may be prime, emphasizing the need for algebraic verification.
Participants generally express differing views on the nature of the ideals discussed, with no consensus reached on whether the second and third ideals are prime. The discussion remains unresolved regarding the proofs and methods for determining the properties of these ideals.
Participants highlight the complexity of proving whether an ideal is prime, indicating that direct algebraic verification may be messy and challenging.
naturemath
This is a basic abstract algebra question.
Q1. Is this (x1, x2) a prime ideal in C[x1, x2, x3, x4] ?
Q2. What about this: (x1 x4-x2 x3, x1 x3-x22)?
Q3. Is this a prime ideal (this is the twisted cubic in projective 3-space):
(x1 x4-x2 x3, x1 x3-x22, x2 x4-x32)?
Thanks everyone.
What are your thoughts??
Hint: I always like to check if something is a prime ideal by checking if the quotient ring is an integral domain.
A1. Yes
A2. Yes
A3. No? Not sure.
-x2 (x1*x4-x2*x3)+x3 (x1*x3-x2^2)+x1 (x2*x4-x3^2)=0 (*)
and
-x3 (x1*x4-x2*x3)+x4 (x1*x3-x2^2)+x2 (x2*x4-x3^2)=0 (**)
Are (*) and (**) relevant at all?
math2012 said:
A1. Yes
A2. Yes
Why yes to both??
A3. No? Not sure.
and
I don't see how (*) and (**) are relevant to this.
So I'm guessing the following.
Yes since the quotient is an integral domain (an irredu variety-- it's the x3 x4-plane).
Q2. What about this: (x1 x4-x2 x3, x1 x3-x2^2)?
No since
x2 (x1 x4-x2 x3) -x3 (x1 x3-x2^2) = x1(x2 x4-x3^2) is in the ideal but neither x1 nor (x2 x4-x3^2) is in the ideal.
Yes, because this is the twisted cubic, which is irreducible.
No since
Yes, but strictly speaking you'll need to show that neither x1 nor (x2 x4-x3^2) is in the ideal.
This is hardly a proof.
Thanks.
Yes, but it seems quite messy to do it directly, using the polynomials.
I'm thinking of writing the ideal (or any ideal) as a primary decomposition, but for even that, is there a systematic way to decompose an ideal in such a way? Or do you recommend other (more) feasible options?
the tricky part is that many ideals have the same zero locus but at most one of those ideals is prime. in the case of the twisted cubic, if an ideal I has the twisted cubic as its zero locus, the irreducibility of the cubic implies the radical of I is prime, but not necessarily I itself. so you have to do the algebra.
Oh I see. Thank you mathwonk!
  • · Replies 31 ·
  • · Replies 21 ·
20K
