Why particles follow path of extremal proper time?
The discussion revolves around the principle of extremal proper time and its implications for the paths of free particles in various space-times. Participants explore the derivation of this principle, its connection to geodesics, and the relationship between classical mechanics and general relativity.
  • Some participants express understanding of how to determine paths of free particles using extremal proper time but question its derivation and generalization to all space-times.
  • One participant asserts that particles travel along geodesics, suggesting that stationary proper time corresponds to the geodesic equation.
  • Another participant challenges the notion that straight lines in flat space-time are always the paths of extremal proper time, referencing the Brachistochrone problem as an example of non-linear paths being faster.
  • There is a discussion about the action for a free particle and how it relates to the principle of least action, with some noting that extremal proper time can be interpreted as maximal proper time due to the negative sign in the action formula.
  • Some participants argue about the necessity of assuming that test particles follow paths of extremal proper time to derive the geodesic equation, while others suggest that it is sufficient to assume particles follow geodesics.
  • One participant emphasizes that the principle of stationary proper time is a foundational principle, akin to the least action principle, rather than something derived from other definitions.
  • Concerns are raised about the constraints on particle motion in gravitational fields, questioning whether the proper time is truly extremal under those conditions.
  • A participant expresses a desire to understand the connection between geodesics in space-time and the actual motion of particles, particularly in curved space-time.
Participants do not reach a consensus on the derivation of the principle of extremal proper time or its implications for particle motion. Multiple competing views and interpretations remain present throughout the discussion.
There are unresolved questions regarding the assumptions necessary for deriving the geodesic equation and the implications of forces acting on particles in gravitational fields. The discussion also highlights the complexity of relating classical mechanics to general relativity through the principle of extremal proper time.
jorgdv
Hello everyone. I understand how to figure out the paths of the free particles following the principle of extremal proper time, but... where does it come from? I mean, how it's derived that particles follow a path of extremal proper time in space-time? I know that for example in flat space-time, the path of extremal proper time is a straight line in space, that agrees with Newton's laws. But how do you generalize that for all space-times?
Thanks
First you need to accept that particles travel along geodesics. Once you do that, you can show that stationary proper time corresponds to the geodesic equation:
[tex]\tau = \int \sqrt{-g_{\mu \nu} \dot{x}^\mu \dot{x}^\nu} d\lambda[/tex]
[tex]\delta \tau=0~~ \Rightarrow ~~\frac{d^2x^\sigma}{d\lambda^2}+\Gamma^\sigma_{~ \mu \nu }\dot{x}^\mu \dot{x}^\nu =0[/tex]
where [itex]\dot{x}^\mu=dx^\mu /d\lambda[/itex].
jorgdv said:
... I know that for example in flat space-time, the path of extremal proper time is a straight line in space, that agrees with Newton's laws.
Au contraire mon ami. Have you ever heard of the famous Brachistochrone problem? Newton was challenged to solve the problem in 1696, and did so the very next day. The fastest path of a ball bearing rolling down an inclined slope from point A to a lower point B is an inverted cycloid. See http://mathworld.wolfram.com/BrachistochroneProblem.html.
Just being picky, but the object must slide without friction rather than roll, which would introduce angular momentum.
In free space the extremal path is a straight line ( in Newtonian mechanics and SR).
That's it, to get the geodesic equation, you need to assume first that the "test particles" follow the path of extremal proper time. My question is precisely about that first assumption.
Actually, they follow the trajectory of maximal proper time!
You only need to assume that particles follow geodesics. The fact that the path of stationary proper time corresponds to a geodesic is derived. The geodesic equation itself can be derived by other methods.
Do you doubt that test particles follow geodesics?
It turns out that the action for a free particle is:
[tex] S = -m \, c^2 \, \int{d\tau}[/tex]
where m is the rest mass of the particle.
In classical (non-quantum) mechanics, the system evolves along those trajectories that leave the action minimal (or, extremal). This is called Hamilton's Principle of least (extremal) action.
Notice that, because of the minus sign, if the action is minimal, then the proper time is maximal. But, you used the term 'extremal proper time'.
In Quantum Mechanics, all trajectories are possible. Each trajectory is associated with a probability amplitude [itex]\propto \exp \left( \frac{i}{\hbar} \, S \right)[/itex]. The total transition probability is a superposition over all the possible trajectories.
In the formal limit [itex]\hbar \rightarrow 0[/itex], which corresponds to transition from Quantum to Classical Mechanics (in classical mechanics, the Planck's constant does not enter), the complex exponential becomes wildly oscillatory, and contributions from various trajectories would cancel. The only uncompensated contribution is from the extremal trajectory, and the whole transition amplitude (path integral) can be approximated by the dominant contribution from the stationary trajectory (see Method of stationary phase, Saddle point method, Laplace method).
Also, I should add that the principle of stationary proper time is just that - a principle. Just like the least action principle, Fermat's principle, etc., it isn't derived by definition.
In free space the extremal path is a straight line in Newtonian mechanics and SR).
In free space in a gravitational field in Newtonian mechanics (NR), a straight line is not the fastest path. For both frictionless sliding beads and rolling ball bearings, a cycloidic path is faster than a straight line. See
There is a similar problem with relativistic charged particles (protons) in strong focusing synchrotrons. At low energies, the higher energy protons have a faster revolution time. But above a particular energy called the transition energy, higher energy protons are slower.
But, is the proper time extremal? Also, you are not allowed to constrain the particle to move along a certain trajectory, because other forces, namely the forces of normal reaction act on it, so this is not a free particle in a gravitational field.
I should have said 'in the absence of gravity or constraints' rather than 'free space'.
The reference you gave does not deal with the rolling ball, so I'll take your word on that.
Well, maybe I'm so concerned about this because this principle is the key to connecting the world we see with the world of general relativity. If the space-time is curved, the metric and the line element changes, and then to know what a free particle in that space-time would do, we use the principle of extremal proper time. So still particles with respect to the big mass fall in its gravitational field due to the change in the line element and because of that, a change in the path of extremal proper time, that is the path that minimizes also the total distance S. So we could say that is a geodesic in space time.
But what I want to see is the connection between this geodesics in space time and the way the particle really moves. I mean, why the particle follows the path that minimize an integral of an "abstract, invariant" term that we defined as dS?
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 36 ·
10K
  • · Replies 20 ·
  • · Replies 95 ·
9K
